Old 03-16-2025, 04:58 PM
Default Mid 1960's Power Antenna
Need some help identifying what these two power antennas fit.
Were supposed to be Pontiac, but the first seems to be Oldsmobile and I need help with the other.
Hoping Scott T or another power antenna aficionado can comment.
Both recently restored and working well.
Antenna 1
2896870 and 2870973 USA Patents
Slight bevel to the upper spacer with W7102 on the underside
OM 6050 Empire 2 T on the upper shaft
ID:	648986   Click image for larger version
ID:	648987   Click image for larger version
ID:	648988   Click image for larger version
ID:	648989   Click image for larger version
Old 03-16-2025, 05:25 PM
Default Power Antenna
Antenna 2
5-14 9AAXA and 2896870 and 2870973 USA Patents on the motor.
Bracket with number 159
Possibly GM part number 3998280 for a mid 60's Oldsmobile
Tear drop / pear shaped upper spacer with 1386370 or 1386376 on the underside
Matching Gasket with 1366344 KF 85 printed on the underside
302500-318 on the upper shaft
3C2300-154 on the threaded antenna cable housing
Any help identifying would be appreciated.
ID:	648992   Click image for larger version
ID:	648993   Click image for larger version
ID:	648994   Click image for larger version
ID:	648995   Click image for larger version
Old 03-19-2025, 01:05 PM
Cerberus's Avatar
Cerberus Cerberus is offline
63-67 vette power antenna gm part number 1#3998280???
CorvetteForum
https://www.corvetteforum.com › ... › C1 & C2 Corvettes
Apr 7, 2017 — According to the 1953 to 1979 GM parts catalog, the part number is correct for 1965-1966 Corvette power antenna. The part was discontinued in 1981 ...
