I have two brackets that that I bought a while ago off a local poncho guy. I was told they are four speed brackets only. Apparently they only come on 4 speed cars. They are like a 14" piece of angle kinda flat on one end with a 1/2" hole on each end. Where do they bolt to?
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
| The Following User Says Thank You to 4dblnkldude For This Useful Post: | ||
I'm guessing these are the ones you are referring to
NEVER DRINK DOWN STREAM FROM THE HERD
Yes! Thank you so much! They go in front of the rear, I though that they went behind.
You are very welcome I just installed a set on my 67 Tempest, I had to do some looking to figure out how they mounted as well (more confusing than it should be) I just couldn't get my brain to look at them and say "oh yeah like this"
Believe it or not. I pulled a set off of a 4 door Chevelle I found sitting at a Junk Yard about 30 years ago. Not a 4 speed car either.
I looked tonight and still cant see it. Yours looks like a 66-67? I have 69.
66-7 are a little bigger/wider
but the 68-72 mount the same |
The frame in the picture I posted is a 69 GTO (not mine although I wish it was) the 67 bars are different ... mount the same but look different.
These are on a 68 frame...
Jimmy M 68 GTO |
I'm missing something. I'll have to get it on the lift. I really appreciate the help!
Duh! I'm beat but went out. I see where they go.
I have a pair off 70 GP and another off a early Monte Carlo.
