Old 03-23-2025, 01:07 AM
grivera's Avatar
grivera grivera is offline
Default Inline Tube Brake Lune Kit, 66 Hardtop, 4 Wheel Disc - - Need Help with Routing
I’m installing an Inline Tube brakeline set in my 66, 4 wheel disc brakes, proportioning valve at the master cylinder. If anyone has installed this kit, I could use a picture of how the lines connect at the proportioning valve? Need to see a front view and also the view looking down where lines go to the frame rail. It’s difficult to figure out with the kit as provided. particularly the proportioning valve to driver’s side front, proportioning valve to meet the passenger front line at frame rail, and proportioning valve to rear line.
Will Rivera
Old 04-01-2025, 05:33 PM
Ragtop Man's Avatar
Ragtop Man Ragtop Man is offline
No good reference here for you, but have you contacted Inline Tube? I'm sure they would try to help you with this.
