Old 03-24-2025, 06:53 PM
Flashflood Flashflood is offline
Send a message via AIM to Flashflood Send a message via MSN to Flashflood Send a message via Yahoo to Flashflood
Default 75 to 77 alternator bracket
I'm in need of 75 to 77 alternator bracket that goes on 350 olds. I've lost mine and can't seem to locate an aftermarket. Thx Andrew
Sent from my SM-S921U1 using Tapatalk
Old 03-26-2025, 01:52 PM
ROCKETMAN269V's Avatar
ROCKETMAN269V ROCKETMAN269V is offline
Default 75 to 77 Olds 350 alternator bracket
I have most every Olds engine bracket ever made. Do you have a/c or not? Any image or illustration of what you need. Thanks, Bob.
The Following User Says Thank You to ROCKETMAN269V For This Useful Post:
Old 03-26-2025, 05:03 PM
So, just to let everyone know what the bracket looks like, I'll post a pic. I had this on my 77 lemans 2 years ago when I pulled the 350 out. All my other brackets have fit just fine to this motor. It is a ac and power steering car so keep that in mind. Your guys help is much appreciated.
Old 03-26-2025, 05:28 PM
It says right on the bracket "'77 Firebird 403". That is a 403 T/A bracket only; never came on a 350 Olds.
Old 03-27-2025, 05:14 PM
Rocket man I understand what you are saying. But than why did my high elevation lemans have that bracket it is not just for t/A it was for high elevation pontiacs with the 350 or 403 olds. What part do you not understand about that. And yes, it is original with a 350 olds.
Old 03-27-2025, 06:32 PM
Originally Posted by Flashflood View Post
.........What part do you not understand about that. And yes, it is original with a 350 olds.
I was a line mechanic for an Olds dealer, back in the '70s. I never saw an A-body with a 350 Olds engine that had that bracket. They needed to use it on the T/As to clear the steering box.
Old 04-29-2025, 08:58 PM
Hey, guys I found one now the only thing I've got to do to turn the key is exhaust stuff, and wiring.
