Old 03-26-2025, 07:06 PM
dv657172's Avatar
dv657172 dv657172 is offline
Default Proper Voltage at Coil
Stock 71 GTO with points
Reinstalled engine after removing for a dipstick tube replacement and car wouldnt start
Determined that the stock Pontiac in dash Tach, which had worked fine prior to engine removal, was grounding the coil. Once disconnected the car ran ok, set dwell (30 degrees), timing (12 degrees), and curb idle at 750 rpm
When I went to start it the following day the car wouldnt start
I was able to get it to start today and run for about a minute but it ran rough and would eventually stall out
Testing the power to the positive side of the coil I have 8 volts with the key on and when the car was running it was ranging between 8 and 14 volts to the positive side of the coil before stalling out
How much voltage should I get with the key on? 12v?
Should it be a constant 14v to the positive side of the coil with the engine running?
Does this sound like a coil issue or an alternator issue?
The tach has remained disconnected since our initial start up issue, not sure why it was suddenly grounding the coil having worked fine before pulling the engine.
Thanks for any thoughts/opinions
DV
Old 03-26-2025, 10:45 PM
Bill Hanlon's Avatar
Assuming points ignition, with the key on, the engine NOT running and the points open, the + terminal of the coil should read battery voltage to ground. With the points closed the + terminal of the coil should read around 8 or 9 volts to ground.
Old 03-26-2025, 10:53 PM
V-Ped V-Ped is offline
With the key on and the points open, you should get battery voltage (12 volts). If the points are closed, you will get a lower voltage - around nine volts. Running, it should average around ten volts. I use the word “around” because the exact numbers are dependent on the specific electrical resistance of your particular coil.
70 Goat
74 Ventura
63 Cat
56 GMC
et al.
Old 03-27-2025, 06:22 AM
dv657172's Avatar
Thanks guys for the info.
