Is there a specified clearance needed for the brake pedal pushrod and the piston in the master cylinder for manual brakes? The car is a 66 Lemans with aftermarket 2 reservoir master cylinder.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress 66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
I set the clearance by "feel". Make sure you're in the upper hole on the pedal. Extend the push rod until there is no longer any clearance, then shorten it by 1/2 turn, lock the jam nut and call it good. If you were running power assist brakes is when you would use the lower hole in the pedal.
| The Following User Says Thank You to 65 Lamnas For This Useful Post: | ||
Thank you! Will give that a go
It turns out my brake pedal return spring is missing. Gotta find a source for one. Searching the Ames website by keyword is worthless.
Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. The mind, once stretched by a new idea, never returns to its original dimensions. |
I emailed Ames and was advised it doesn’t use a spring. I see the hole for it and it has the little tab on the clevis pin. I think I e seen a diagram showing it.
http://forums.maxperformanceinc.com/....php?p=6468974 Good pic of it here in #5 post.
Thank you - that is great. May have to source an off the shelf spring.
Found the spring at Musclecar Central: https://www.musclecarcentral.com/196...p/ppd-831b.htm
