Old 03-31-2025, 06:46 PM
spawn_x spawn_x is offline
Default 1973 GP clutch pedal/manual swap
Hello folks. My parts list so far that I have:
Quicktime RM-8070 bellhousing
McLeod 462101 166t flywheel
McLeod 75221 flywheel
RAM hydraulic throwout
TKX .68 trans
Going into a 73 Grand Prix behind a 455, currently a th400 in it
My question, what do I do for the pedal? I bought a pedal from opgi
https://www.opgi.com/interior-access...e-G241494.html
But what do I need for the rest? Is this a good option?
https://www.malwoodusa.com/uncategor...servoir/?gQT=2
Ive not looked closely yet, but will the pedals simply bolt up to existing bracketry in the car? Or do I go a whole separate unit like above?
Much appreciated. Thanks
Old 04-01-2025, 05:43 PM
Apparently there is an install video on their site. Answered most of my questions. I will buy it and see how it goes I guess
Old 04-01-2025, 06:16 PM
72projectbird's Avatar
I can't be of any help, as I've never manual swapped a GP before. That said, it's awesome that you're doing it! Should make it a blast to drive
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 04-01-2025, 06:25 PM
chris66's Avatar
chris66 chris66 is offline
If you can find parts from a 1973 to 1975 Grand Am, LeMans Manual transmission car
That would help with the necessary parts
I have a website for cars and parts that I am selling:
http://www.gto-by-pontiac.com
Old 04-01-2025, 08:20 PM
chuckies76ta's Avatar
This will be my next unit. I'm my opinion this is the best setup on the market for a manual setup. Malwood.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick.
Best so far 9.95@135 mph. 1.39 60 ft.
468 with KRE D-ports, Doug headers, 3" Exhaust
950 Quickfuel.
Old 04-12-2025, 05:14 PM
So I bought the Malwood setup.
Bolts up! Needed to make a small 1/4" dent on the firewall because the GP has a cowl thats different than Monte Carlo apparently, but it BOLTS UP to my surprise.
Ross @ Malwood is knowledgable, and the money on the unit was WELL SPENT
Bellhousing is aligned with .007 dowel pins and in spec, Flywheel, Pilot Bearing, and Clutch installed.
Going to put another couple hours into this today and see how close I am to finishing. I will take some pictures.
