Old 04-02-2025, 03:17 PM
napster's Avatar
napster napster is offline
Default New Combo
Wondering what you guys think about the following combination for an upgrade to one of my 1978 S/E T/A’s. I will be using Items I have instead of going out to purchase new aftermarket parts.
Current combo – 406 CID W72 block, Edelbrock performer intake, XE 274H-10 cam, Forged pistons, forged Eagle H-beam rods, Stock crank, 6X#4heads with port match and cleanup of bowls, 9.45 to 1 compression, D port Doug’s headers. Horsepower is 370 -380.
New combo – same 406 CID W72 block, 234 factory intake manifold, Butler RA IV roller cam. Same rods, pistons & crank. RAII heads, round port Doug’s headers, 10.25 to 1 compression.
Cam specs – https://butlerperformance.com/i-3164...tegory:1234841
Estimated HP 450.
Let’s hear it.
Thanks in advance.
Old 04-02-2025, 05:17 PM
steve25 steve25 is offline
With what I have seen from having the RAII heads on the flow bench they flow like most any stock D port at lifts above .450” and flow really well on the exh side, in fact so much so that since your running headers I don’t think you want to run a cam with more exh duration then intake duration, since the headers themselves will pick up 4 to 5% more exh flow at lifts above .250”.
Note also that the stock tulip RAII intake valves are not the way to go.
The normal replacement nail head types flow better with that intake port.
Also on the subject of cams you did not mention what you have for rear gears?
That RA4 roller cam is going to act a good amount bigger then that 274 cam.
Old 04-02-2025, 05:19 PM
napster's Avatar
3.73 gear.
Old 04-02-2025, 05:24 PM
JLMounce JLMounce is offline
Is there a reason an Edelbrock performer rpm head isn't be considered? Or just want the cool factor of having the RAII heads?
I like this build either way. Should be kinda rowdy.
-Jason
1969 Pontiac Firebird
The Following User Says Thank You to JLMounce For This Useful Post:
Old 04-02-2025, 05:26 PM
napster's Avatar
Want to use parts I already have.
Old 04-02-2025, 05:28 PM
Had a feeling you probably already had a set, that makes sense.
-Jason
Old 04-02-2025, 05:54 PM
John Milner's Avatar
John Milner John Milner is offline
Should run very well. I run a 10:1 428 with 614's and a 236/244 hydraulic flat tappet camshaft, Doug's headers, factory IV intake and a Quadrajet. It is plenty streetable, never overheats and will turn the tires into smoke with a 3:23 rear gear and a 4 speed.
The Following User Says Thank You to John Milner For This Useful Post:
Old 04-02-2025, 06:01 PM
Stock exh flow comparison @ 28” casting #62 and RAII.
.100”////43.4//// 35
.200”////82.2//// 84.7
.300”////120.2//// 122.6
.400”////139.7//// 161.6
.450”////149.3//// 174.4
.500”////155.6//// 190
.550”////159.1//// 201.2
.600”////162//// 206.3
.650”////165.6//// 210.3
The Following 2 Users Say Thank You to steve25 For This Useful Post:
Old 04-02-2025, 07:21 PM
JB Eng Wis JB Eng Wis is offline
Steve25
what flows better in 6X heads Ferrea 12 *undercut or their 9* flow dish?
2.11 intakes
Old 04-03-2025, 11:36 AM
While I do have two stock 6X-4 heads on hand I do not have either of those valves
Old 04-03-2025, 03:20 PM
Dragncar Dragncar is offline
RAIIs are worth a lot of money to the right person. You could just about get any aluminum head you want with the cash.
The Following User Says Thank You to Dragncar For This Useful Post:
Old 04-04-2025, 03:04 PM
napster's Avatar
Steve25,
It seems the solution to the flow of the intake and exhaust of the heads is to port the intake and leave the exhaust side alone. When it gets to a proper increase on the intake side it will allow the dual pattern cam to run with no problem.
Old 04-04-2025, 03:38 PM
Verdoro 68's Avatar
You could...but everyone has a set of aluminum heads. I personally like opening my hood and showing off a set of factory round ports in a sea of aftermarket heads, even if very few people notice.
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 4 Users Say Thank You to Verdoro 68 For This Useful Post:
Old 04-04-2025, 04:26 PM
Gary H's Avatar
Gary H Gary H is offline
What carburation?
Old 04-05-2025, 11:40 AM
napster's Avatar
Holley Brawler 750 CFM Double Pumper
