Old 04-04-2025, 10:42 PM
Squidward's Avatar
Default For those real "cool" cats: What's your recipe?
There are those here whose cooling system is aces. Their cars never get off the thermostat, or they can idle in a drive thru for an hour with the AC on, in 110 degree heat.
I was wondering if anyone with these highly successful cooling systems would be able to share their formula with common criteria. Maybe even include stats on performance in various ambient temps. Looking to see what WORKS.
Platform (year and model):
Engine (mild to wild):
Water pump config (8 bolt, 11 bolt):
Water pump style (cast impeller, stamped impeller, special aftermarket):
Water pump pulley size (small/med/large diameter):
Lower hose spring:
Radiator (# rows, material, brand):
Tstat:
Cooling fan configuration (blades, clutch specs, electric, etc.):
Typical use factors, like ambient temp, AC, etc.:
Any special mods:
So I'll get the party started with the template, even tho I wouldn't consider my setup an example of highly successful. In fact, mine needs some help.
Platform (year and model): 1967 Firebird
Engine (mild to wild): mild 350P, I would put it at a 2 out of 4. Hotter than stock. FiTech.
Water pump config (8 bolt, 11 bolt): 11 bolt
Water pump style (cast impeller, stamped impeller, special aftermarket): Factory style cast
Water pump pulley size (small/med/large diameter): Small diameter
Lower hose spring: No, but have one arriving this week!
Radiator (# rows, material, brand): 4 core Champion, aluminum.
Tstat: 180
Cooling fan configuration (blades, clutch specs, electric, etc.): 19" GM, Hayden 2797 clutch
Typical use factors, like ambient temp, AC, etc.: Super hot summers. Car has AC, but is not used currently. Temps creep at idle, temps creep while cruising.
Any special mods: divider plate clearanced.
Old 04-04-2025, 11:09 PM
No secret formula here but scirrotica solved all my idle temp woes with this cheap flex fan:
https://www.summitracing.com/parts/DER-17019
Old 04-06-2025, 07:04 AM
Squidward's Avatar
Will keep that in mind. I have a factory shroud, good fan depth. Maybe the system is fully coated with scum, or my divider plate rotted away unknowingly. I've always kept a good antifreeze mix. I have baffles between the bumper and core support to keep air going into the radiator. I can't imagine my open RA hood scoop inserts are drastically interrupting under hood air flow much.
It's not that mine DOESN'T work, but it definitely underperforms.
I'm hoping some others chime in with their cool setups.
Old 04-06-2025, 09:47 AM
One sage here told me that if the temp goes up when it's idling then it's the fan/airflow.
My old non-stock fan was too small and didn't push enough air.
How far does your stock fan stick out of the shroud? Or does it?
Old 04-06-2025, 10:33 AM
burd burd is offline
Water pump divider has to be set, I didn’t do mine, a guy in Miami did it, I never overheat now. I use a 160 thermo too. I can have ac on in Dreamcruise, no issues.
Test your rad cap, even if it’s new. We tested 3-4 new ones at the natz last year, they didn’t hold rite out of the box.
Old 04-06-2025, 10:50 AM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Wink cooling
ok throw my 2 cents in on this topic
My cars setup is as follows.
-11 bolt waterpump with tight clearance to divider plates
-Cold Case aluminum radiator with TH400 cooling lines in use in rad
-all factory baffles to direct air into radiator and seal around core support
-original fan shroud my car was born with
-converted to AC pulley for crank and waterpump to speed up water pump and fan
-factory AC 7 blade fan from 76TA using a hayden STD duty fanclutch
-NOS AC Delco 170 degree thermostat. verified to crack open 165 and fully open 180.
-Q-jet 7028276 with proper recalibration done during rebuild and full RA pan setup
-factory HEI with 12 initial 32 total using heavy advance springs for conservative curve.
weird thing is my car idles butter smooth and has more toque off the line with slower
curve. also 12 degrees from VAC ADV and have tried both ported and FMV and neither
effected cooling. but I prefer exhaust note from FMV at idle(today anyway).
-with 3:08 on highway she is happy at 75 and runs just shy of 180 and then drops back down to 170 on backroads. never hear fan clutch engage and happy with cooling.
In my garage for wall art, are the original crank and WP pulleys and 5 blade. they worked
well for years but temp did creep up in traffic. All these changes occurred over 15 years.
biggest bang for my buck was to speed up WP but then factory 5 blade fan was too loud on
highway. thus, installed matching fan clutch and shortly after has to replace leaking radiator and Cold Case was installed. Gas mileage did improve with fan clutch change.
this is just what worked in my car. I have a collection of thermostats that worked and some that were crap. current Delco stat was installed with no additional holes or voodoo.
All original parts were saved if I ever wanted to go back to original setup.
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
Old 04-06-2025, 02:58 PM
george kujanski's Avatar
george kujanski george kujanski is online now
Clearanced 11 bolt pump, Shroud, clutch fan, Cold Case radiator, 180 degree thermostat, 12 degrees BTDC, manifold vacuum.
George
Old 04-06-2025, 04:16 PM
Sirrotica's Avatar
Sirrotica Sirrotica is online now
I'm glad that helped you out, I started using those composite fans in the late 70s and they have always been affordable to buy, and do away with all the extra weight, and mass hanging on the extreme end of the water pump shaft. If the car starts to get hot in an idling situation that fan will pull enough air if you rev it in neutral to bring the coolant back down quickly.
If you keep the basic principles of physics in mind and science out cooling system problems you can pinpoint and fix your woes.
Plenty of air through the radiator, no restrictions in the system and as much volume of coolant as possible in the system. Overdrive the pump to keep pressure high to minimize steam pockets and run the coolant as fast as possible through the system.
Thermostat, or a restrictor need to be in the system to keep water pressure high in the engine. Coolant rejects or takes on heat at the speed of electricity, so the old wives tale that you can run coolant too fast through a system is false.
GM had cooling woes in their 6.5 turbo diesels, one of the changes they made was to run a water crossover with dual thermostats converging into a single upper radiator hose. The purpose was to allow more volume of coolant through the engine and radiator. With 2 thermostats the flow was higher, but still had a restriction to keep water pressure in the engine high. Water pump was modified to pass a higher volume of coolant and the increased the size of the fan as well as reprogrammed the fan clutch to come in sooner at a lower temperature.
If you're running and automatic transmission. and you're borderline on overheating don't use the cooler in the radiator, use a separate cooler.
Keeping a dirt track Pontiac cool during the summer running for 20 laps in the features made me find answers to why they overheated, and what measures I could use to eliminate the O/H problems. Lots of experimenting and research went into the cooling system, at the end I could run 20 laps and never get the coolant above 180, no matter what the ambient temp was.
I hope this helps someone having cooling system problems..........
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 04-07-2025, 12:52 AM
Squidward's Avatar
Good point.
Personally, I run out of the trans, to external cooler, to radiator cooler, and back to trans. I've always reasoned that the external pre-cooler took load off the radiator, and if anything, the radiator could even add excess heat back IN to the trans fluid to get it to normal fluid temp in case it was cold outside.
Old 04-07-2025, 10:54 AM
srmmmm's Avatar
srmmmm srmmmm is offline
I think I have the opposite problem of most posters, over cooled in town and under cooled on the highway. With a 180 degree thermostat, I barely see 165 in town or at steady idle. Running the A/C will get it up to 180.
At 70 mph though, it's running at 210 and will run 230 with the A/C.
1700 miles on Len Williams built engine. Original 1970 350 block stroked to 413, XE276HR cam, Torker-I intake and 800cfm Q-Jet, 6X-4 heads, 9.3 cr
TCI Turbo 350 with 2400rpm stall converter, 3.23 rear axle
Original 4 row radiator, has been "overhauled" twice with lower row replacements. Internal Turbo 350 transmission cooler used. 24 quart cooling capacity
Edelbrock 11 bolt water pump with CNC impeller
Original 7 blade fan with new Hayden H-duty clutch
CVF serpentine belt drive - appears to be at least a 10% overdrive from the crank pulley to the water pump pulley
14 degrees initial timing, 21 mechanical all in at 3200 rpm, MSD 8563 distributor vacuum advance connected
I'm beginning to think the radiator has been painted too heavily and can't dissipate heat fast enough at higher engine rpms.
Name:	#57 Engine Installed.jpg
Old 04-07-2025, 11:46 AM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
1979 Trans Am W72 400/4-Speed; stock low-comp 400 with a mild camshaft and true dual exhaust; everything else more-or-less stock. I'm running an 11-bolt Flowkooler clearanced down to 0.050" w/ gasket; Oversized 1.25" 2-Row Cold case radiator; new copper/brass heater core; 160 degree thermostat (balanced sleeve type); all new hoses and lines with anti-collapse spring in lower hose; 15 PSI rad cap as original; stock fan shroud; stock 7-blade 10008888 19" clutch fan; Hayden #2747 heavy duty clutch; shroud sealed to radiator with weatherstripping; all factory baffles and seals in place; stock overdriven AC waterpump pulley; stock HEI with 18 degrees initial timing as per factory spec; vacuum advance metered through the factory modulator valve that supplies partial manifold vacuum to the distributor (around 17 degrees of the full 25 degrees the advance canister supplies), and so I'm making 35 degrees total advance to the distributor at idle. Mechanical advance around 34-35 BTDC by 3500 RPM. Cooling system jackets clean as far as I can tell, since every flush I've done has never revealed dirty coolant - it always comes out green. I use Napa 50/50 pre-mixed conventional green coolant and every couple years as part of a backflush and refill, I throw in a bottle of Rislone Super Coolant additive, cuz why not?
I live in SoFlo, and around town, my car struggles to reach operating temp and I can idle till' the cows come home and the needle will almost never reach that first tick on the temp gauge (which for 2nd gens, I've always interpreted as around 160 degrees), no matter the ambient temp. I can drive around town for an hour and literally grip my hand around the radiator hose and hold it without getting burnt while the car is running.
My temp will creep up to the first tick, maybe a little past it when I'm on the highway sustaining higher RPMs, and that's after roughly 10-15 minutes on the highway. I've never been on the highway long enough to see how high the engine temp will go since I have a driveline vibration above 60 MPH that I need to address, so I usually avoid taking the highway, anyway. I have the factory 3.23 gears, and so in 4th gear on the highway, I'm at around 2250 RPM at 55 MPH, so figure around 2800 RPM at 70 MPH.
The AC, however, will cause my engine temp to spike very quickly. I think something may be wrong with my compressor or AC system, because while it does blow cold air, it taxes the engine a lot and just sitting there idling, I've seen the temp needle creep to halfway between the first tick and 220 tick on the gauge within maybe 8 minutes before I freaked out and shut off the AC. It's been converted to R134A, but only had the lines and compressor replaced with a crappy reman unit, while the condenser and evap are still the originals. I usually drive the car in the evenings, so I don't use the AC.
Overall, I'm pretty happy with the performance of my cooling system for living in SoFlo. Leagues better than when I first got the car, even though even then, it has never overheated. I just wish I could more confidently use the air conditioning, since living in SoFlo without it is oppressive and you need to make a lot of concessions to be able to enjoy the car without it (i.e. driving it only at certain times of the day when it's not as hot out, or depending on what time of the year it is).
I also think that people's standards for how these cooling systems operate are a little high, especially in accordance to the factory specifications as shown in service and owner's manuals. People get awfully paranoid just seeing their car in the 190's-200's, when in reality those are totally normal operating temps which these cars regularly saw when new. So many of these overheating threads may not even be based in actual overheating, but rather, "car not running at a temp that I, the owner, personally like to see it at."
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
Old 04-12-2025, 08:51 PM
Squidward's Avatar
I appreciate all the posts.
Yesterday I was out driving my 67 FB. It was 100 out.
Average temps while cruising at 45-50 mph were 195-200. Idling would get a little hotter. I did see 215 in a drive thru. This was without running ac.
In a conversation with a fellow 1st Gen enthusiast locally, we talked about maybe this is as good as it gets, but I don't want to accept that yet.
2nd gens have bigger radiators, so that might give them the better cooling nod there. And maybe the air flow through the nose/grill/cowl is also better.
I get tripped out occasionally that the 5.3 in my 04 GMC can be cooked by a skinny radiator, 5" wider than my bird, with plastic tanks.
Keep those recipes coming!
Old 04-13-2025, 12:47 AM
srmmmm's Avatar
That's the heat transfer difference between unpainted aluminum and painted copper/brass.
Old 04-22-2025, 02:25 PM
Squidward's Avatar
Finally stole a moment to try something. In searching for a tstat, I saw a number of standard vs deluxe stats, and some listed as high flow. Since I had planned on swapping perhaps to a 160, I wanted to see if 160 was even possible. So I pulled the thermostat, and went without one. I buttoned it up and went for a drive in wonderful 67 degree night air, not many more of those left.
Previous night drives have given me 185-188 while doing 45-50 mph at 2500 rpm. Highway jaunts might poke it up a few degrees while buzzing at 3500 rpm. Idle at a light causes a few degrees more creep.
This drive took a long time to heat up, as expected. It took at least a few miles, including highway, to crack 160. After several more miles of town cruising at 45-50, my steady state temp ended up around 171. After the drive, I let it sit at idle for several minutes. It crept up, and reached 195 before I decided to call it a night.
My hypothesis? I'm thinking that my basic 180 tstat was providing a flow restriction that did not allow full cooling ability. Having no tstat gave an extra 15+ degrees of extra cooling for similar driving conditions.
The idle creep still bothers me. It makes me think airflow issue. I have a few other fan combos laying around for further troubleshooting, including a six blade flex fan.
Next step will be lower radiator hose/spring, with system flush, then another data set.
Old 04-22-2025, 03:39 PM
The issue is, that restriction the thermostat provides allows for pressure buildup in the system to further protect from boiling the coolant in the event that you do start to run hot. Maybe try a balanced sleeve thermostat (the "hi-flow" ones you're seeing).
Also, what's your tune? Initial timing, are you using vacuum advance and if so, manifold or port vacuum to the distributor? Airflow is indeed the most important factor for idle temps, but ignition timing plays a big role, too.
Old 04-22-2025, 03:51 PM
Sirrotica's Avatar
I'd bet if you put one of these on your low RPM creep will disappear:
These are called RV fans, and are intended to move a ton of air at low engine speeds, they do just exactly that. At idle you can feel how strong the suction is in front of the radiator by standing there.
My radiator shop guy showed me with cigarette smoke how little air the clutch fan was moving at idle. At that time in the late 70s the fans were under $20, so I said I'm going to try one. It one of the best cooling moves I ever made. The prices have doubled since then, $29.99 but still a good buy. The largest they make is 18 inch, but it still works better than any 19/19.5 fan I've tried.
https://www.summitracing.com/parts/aaf-all30095
The difference between this fan, and a conventional fan is the almost 90 degree pitch on the fan blades, that's what allows it's ability to move air at low RPM.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 04-22-2025, 04:05 PM
Squidward's Avatar
14 initial, running somewhere around 12 degrees manifold vacuum advance. It likes a little more, but I wanted to be reasonable with the rest of the tune. I am a fan of manifold vacuum advance for the idle performance.
Old 04-22-2025, 04:08 PM
Squidward's Avatar
I read about your fan suggestion to King Buzzo in an earlier post, and it had my attention. Yeah, needs more air. Can't really beat the price.
Any input on the durability of that fan? Any thoughts on whether to hard mount on a spacer, or mount on a clutch? Thanks!
Old 04-22-2025, 06:20 PM
Sirrotica's Avatar
You hard mount to a spacer, no clutch involved. Another bonus is dropping a lot of weight off of the end of the water pump shaft. The extra load from the severe pitched blades would likely make a clutch slip so direct drive like the factory did for decades.
I've run them on my dirt cars for 3 seasons at about a 5500-5800 RPM redline. After I took the fan off of the race car I put it on my 1973 T/A street car and it was on that car (5-6 years).
I borrowed it for an enduro car, the front end got crunched and the fan hit the radiator and the blades broke. The amazing thing is the plastic blades did very little damage to the radiator, unlike a metal fan blade does. I was able to solder 2 tubes up on that radiator and kept using it. I can't think of any downside to substituting a composite fan for the heavy metal clutch fan.
For $30 and some spacers and bolts, it's hard not to justify at least trying one......
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 04-22-2025, 10:47 PM
I bot a spacer with my new fan but didn't end up using it as it lined up nice on my 2nd gen...measure twice
