Old 04-13-2025, 07:11 PM
64Lemans 64Lemans is offline
Default Mice Issue
Hello.
My 1964 Lemans was stored over the Wisconsin winter, outside in a field.
Now I have the following items to take care of.
1. The trunk had water in it. Thanks to a previous post on this forum. Due to the water, there was rust in the trunk that needed to be addressed. I am almost done with addressing the trunk.
2. Next Project (Mice). There were mice droppings in the inside of the car as well as the trunk. In addition to the trunk, I plan on taking out the seats and replacing the carpet.
Question #1. As far as the seats (front and back) any suggestions on that. Should I spray the underneath and/or backside of the upholstery to help with the smell. I've read that maybe 1/2 part vinegar and 1/2 part water would do the trick.
Question #2. Thinking about other popular spots for mice, what is the diagram / layout of the ducts / vents. No a/c here. I am wondering if I should take all related vents apart to inspect and clean as needed. Does anybody have any prior experience when it comes to that or have any other ideas before I start taking everything apart.
And lastly, is there anything else I should check at all regarding the mice? Seems like all my lighting, radio and other power functions all are working. So hopefully no wire chewing occurred.
Thank you.
The Following User Says Thank You to 64Lemans For This Useful Post:
Old 04-13-2025, 10:24 PM
GtoFM's Avatar
GtoFM GtoFM is offline
Are you sure they are gone? They get everywhere and anywhere! When I dismantled my '64, there was evidence under the seats, behind the dash and above the headliner where the dome light wire harness runs through the structural sheet metal.! They eat the insulation off the wire, and you may not have problems until they short to ground or corrode. Inspect as much as you are able.
Old 04-13-2025, 10:58 PM
Originally Posted by 64Lemans View Post
Hello.
Thank you.
The ONLY thing I have found that WILL get rid of mice in an enclosed area is Grandpa Gus’ mice repellent.
Dr. Thomas Sowell
The Following 2 Users Say Thank You to hurryinhoosier62 For This Useful Post:
Old 04-14-2025, 08:24 AM
thank you for the replies.
are the mice gone? well i moved the car to an enclosed storage.
set a few traps underneath the car as well as in the car.
nothing over the last 2 weeks. no additional droppings as well that i can see.
as far as the headliner, oh boy, w/o taking that apart, look for signs of smell and/or spots on the liner?
as far as the ducts / vents, i was told if i turn up the fan on high, see if anything material comes out of the vents, chewed up insulation, etc... would that work, or would you recommend taking some vents aparts to inspect, etc..
i haven't inspected underneath the dash yet, seen one small piece of insulation on the floorboard, but other than that, nothing.
Old 04-14-2025, 08:46 AM
mgarblik mgarblik is offline
One of the very favorite places mice love to nest is inside the heater box. They love the squirrel cage. They will pack it full of firewall insulation and produce generations of tiny offspring through the winter. If not too difficult, I would pull the blower motor and clean/checkout that area.
Old 04-14-2025, 08:52 AM
thanks..
so the heater core and the heater blower?
does the fender need to come off to get to the removal of the heater blower?
Old 04-14-2025, 08:53 AM
steve25 steve25 is offline
The air cleaner is a popular winter vacation destination also .
Old 04-14-2025, 02:34 PM
OG68 OG68 is offline
After spending $2000 dollars to replace a chewed on under hood harness in my new Cadillac I use Grandpa Gus's pouches and some 'sticky traps'. Caught a few shortly thereafter and haven't seen any activity in the last 6 months since.
Old 04-14-2025, 06:48 PM
Half-Inch Stud's Avatar
I put the poison pellets in the trunk and that is a good witness for any mice activity. Soon to be inactivity.
Old 04-14-2025, 09:54 PM
Sirrotica's Avatar
I've posted links here before about using this non poisonous homemade rat and mouse killer. Here's a link to a 3 year follow up with one of the original posters of the mouse killer videos:
https://www.youtube.com/watch?v=ZLvpNIO84hA
I first stumbled across it on You tube a couple years ago and tried it. I live in a 120 YO farmhouse and we have a stone foundation that has all types of voids and ways for rodents to get into the house. At that time I had a mouse problem and figured it wouldn't hurt to try it. I used some Planters peanut jars with a couple 1 inch holes drilled about an inch and a half from the bottom opposite each other.
The first night I placed it in the kitchen there was baking soda and muffin mix all around the jars. The second day much less powder around the jars, and the activity was less and less each day. Within a week there was no more bait being scattered, nor any evidence of traffic in the jars. The evidence of droppings stopped completely. It flat out works because rodents love wheat based bait. The baking soda causes gas internally when it mixes with their stomach acid, their digestive tract can't release the gas fast enough, their digestive tract ruptures, and they bleed internally.
If you made up a few jars and left them in and around the car in the fall, it should kill them all through the winter. I hope this helps someone save their car from the mess that rodents make, and the expense and work of cleaning it up in the spring. Bonus is no poison in the carcass in case a dog or cat eats the leftovers, safe around kids too..............
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 04-14-2025, 10:14 PM
burd burd is offline
A buddy bought a vehicle in Vegas, it had a rat in it. Brought it back to Michigan.
Old 04-14-2025, 10:27 PM
GtoFM's Avatar
Heater: Using a bore scope, you may be able to ck the cabin side with minimal duct removal. The engine bay side will require a lot more work, at least the inner fender removal.
Headliner: If no staining, I wouldn't pull it unless a smell remains and only as a last resort.
Old 04-14-2025, 10:32 PM
GtoFM's Avatar
My '64 followed me thru 3 moves. When I finally pulled the back seat, this is what I found...RATFINK!
Old 04-15-2025, 10:00 AM
78w72 78w72 is offline
The only problem with poisons or other things like baking soda that kill the mice internally after a day or 2... is that they go back to their hiding places & die, that can be in walls of your house or nooks & crannies or areas in a car that dont have very good access... they die in there & start to stink which requires removal or waiting a long time for the smell to go away.
Best to use a traditional trap so they can be disposed of or make one of the DIY ones with a bucket of water & some type of bait on a board that pivots when they go for the bait then fall into the water & cant get out... theres vids of those traps on youtube, can kill 20+ in 1 day if you have that big of an infestation like on farms etc.
When I was a young teenager I caught a squirrel and put him in a big box in my room in the basement, had a friend come over and let him lift the lid to look at it... the little bast*rd jumped out across the room (those buggers can almost fly) and got into the closet that had access to the space between the basement ceiling & upstairs floor where HVAC ducting runs... had to call a professional rodent guy to get it out... he said you dont want it to chew a electric wire or get stuck and die up there as it will stink the entire house for months & cause a real problem. He put a live trap in the room with a trail of apple pieces to catch it, luckily got it within 24 hrs.
Be careful with using things to kill the mice/rats after they eat it, traps are best to get rid of them.
Old 04-15-2025, 11:16 AM
PAUL K's Avatar
PAUL K PAUL K is offline
We found that mice like Irish Spring soap
We found (for some of the reasons already mentioned) traditional traps work the best and are most humane. Use peanut butter and stick it in the corner near the wall. You'll know when you need to set more traps.
The above strategy turned a problem into a non issue.
Go fast, see Elvis!
Old 04-15-2025, 12:11 PM
Get a cat. That’s the best.
Old 04-15-2025, 12:43 PM
Sirrotica's Avatar
I have 3 of them, and I have mice, so much for cats being the best.
Also cats can't get inside of cars, but they can walk around on the paint making scratches.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 04-15-2025, 01:13 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Yep. When I took by blower motor out of a `71 Lemans with factory air, there was 1 1/2 hole chewed through the plastic squirrel cage. No nest.
Old 04-15-2025, 01:44 PM
Fix any places mice can get in, most people don’t ever walk around their place and look for places they get in. Also adjust your doors to close all the way down. Put a weather strip,or place what’s there. Most people don’t ever adjust or lube their gage doors either.
Old 04-15-2025, 02:56 PM
thank you for all the feedback.
i think I'll be purchasing a few things.
the scope for sure as I don't want to rip apart everything if i dont have to.
question - where would you shop for replacement carpet. i would like to get as close to original as possible. not sure about the 80/20 loop pile? etc...
