I live in the Netherlands and got a starter send to me by a relative. Not what I asked exactly, but I was wondering if it's any good? Can't find a whole lot on the brand. It's a Pro-Tork Mini performance Starter from what I believe is Alterstart Systems. Thought I better ask if someone has any info on them before I put it in!
Alterstart is not a brand that I am familiar with but I looked on line and it had good reviews. Maybe someone else has more information.
Don’t have any info on that brand but most of the companies get thier starters at the same places
Just be sure you lock tight the bolts that hold the adapter plate on if it’s on you can clock otherwise it will Loosen up on you. Most of the mini starters today are pretty good from what I’ve seen
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
