Helping a local guy with a Pontiac motor in a 81/78(81 car 78 nose tail) 5 speed.
New motor Kaufman D port top end Performer Crower HFT, DUI HEI.Holley Street Brawler carb, headers. Nicely done car. Original distributor was doing strange stuff (I was not there) when he test fired it and ran it to break in cam, so got a DUI. I have 3 in most of my Pontiacs and all work flawlessly. So putting the tining light on it is when it gets weird . It is an electronic light. Liked about 30 BTC at idle! DIU has 24 degrees in by 3000. Rev it it RETARDS for a second then goes back to where it was at idle! Consistently the same. Vacuum unhooked(It adds 10 degrees. Pulled cap off and advance weights not sticking and go the correct direction. He did put a whole new Painless wiring harness and the 12V wire he just has a spade connector and to me looks like a smaller gauge than factory wires. Not enough juice to module? It does not make sense to me it retarding then advancing but not any more than I had it at 800 rpm idle. Carb having primary accel pump issues, takes a lot of throttle movement to get fuel out then it squirts. Lever moves with throttle. I adjusted the slack out of spring. It does it every time so not like it is building pressure. Thinking either check valve in bowl or under squirters for that. I can figure carb out or even swap on one of my extras but the timing has me baffled!
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Hope someone has some input. Sounds frustrating !
Going from fuzzy recollection I think the DUI system uses a touch more current than OE so wire gauge may be important... was the advance cam right side up for pontiac?
........... The More You Follow The Herd The Less You Can Be In The Lead .......... |
There has been a time where a holley carb squirter was lethargic with light and slower activation and I bent the bar that holds the check ball in place on the float bowl so it would activate a touch quicker, very slight bend ya can over do it
Skip I bet you have an issue like that other fella had the other day that had a post up.
I’d bet there’s an issue with a flaky Dyna Mod module. Most will say it’s the timing light, but I’m gonna be honest about it, I’ve never seen that on my end. I’ve had the straight craftsman blink light they sold, and the same one with the dial back knob both. I will say the dial back craftsman was fine if turned to 0 and used as a straight blink light. No issues there for me. Now the thing was off a few degrees from what the knob said but it was off all the way up and down the same number. I’ve seen most lights that get the pickup banged on the concrete when they get rolled up and stuck in/banged off the fan….well I can’t tell you about that they will all be off if you make a go it of that nonsense, but that’s not you. 95% sure you have a wacky Dyna Mod. I bet that West Coast Gto fella got the same thing going on. And if so … then perf Dist has an issue I warned em about a year ago… The supplier of these modules is now and has been the under the same umbrella for about 2 years now. And if that’s the case, the world has got problems coming they yet not realize is coming with these modules. Short answer is call em and see if they’ll warranty it, I think they will. Ask for Brian. 901-396-5782. Immediately short term, grab one from your favorite parts place(good luck and Godspeed), or better substitute in a good known used one for the short interim. Let us know what happens… |
What Formulas said plus look close to see if carb is sitting too close to intake manifold and squashing pump arm wasting travel motion…. Look at it, seen that before on small chevies.
While not the main issue the use of a lighter then required wire will reduce the needed available current as the firing rate ( rpm. ) goes up .
Did you check for 12v to the dist? It’s possible the harness is wired for points and has a resistor wire for power? Maybe run a jumper wire straight from the battery. Also make sure the dist has a good path to ground.
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55 '72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80 |
I experienced what sun tuned explained. Some of these modules (I should say many lol) are whacky. They do weird things with the dwell time and affect timing.
I'd swap in a known good module and try again. |
This is very interesting to me. I'm having some issues with my car as well - distributer and electrical is the issue (not the carb). My situation is inconsistency in timing/etc. With my 68 Lemans/455. I have the Americal Wire harness/fuel box kit. The wire (yellow) that goes from the engine fire wall bulk connection block I used a wire that is what I believe could be smaller that what it should be. Note: the 68 wire to the coil is a 2 wire set up. One wire to the coil is for start and the second wire (yellow) is for run. In this case my run wire is a smaller wire/Guage then I believe might be causing my issue.
Definitely put a voltmeter on that 12v feed wire and see what’s going on there, at key on, start, and while it’s idling.
Easy enough to pull coil cover and then you can get right at it without issue. The original feed wire from GM was a strange deal. It was about between a 12 and a 14 gauge wire conductor with an over size large diameter of insulation. With using up to date modern type wire a 12 gauge wire is quite sufficient. I’ve seen all kinds of goofy stuff done with the feed wire going to these HEI distributors on cars. Too small gauge wire for sure won’t have the current carrying capacity it needs. Most HEis will only draw about 1.2-1.7 amps(Stock) the coils used in the DUI will only draw about 1-1.2 amps more than stock, so a total of 2-3 amps total at most. My all time favorite deal to see on cars is where they pulled a points distributor and found a 12v keyed source to run the HEI that’s hot in the start AND run position and then run the distributor off that. At that point that’s a good deal…but then they pull the old carb and upgrade to one with an electric choke and then find theres not much places to find a choke power wire …so they T into the one powering the distributor. I don’t like that. Second favorite boo boo is where they try to power the choke off the positive side of a canister type ignition coil… Yeah it’ll work, but not the most ideal situation at all. |
With a smaller gauge wire used anywhere near where engine heat can soak into it that heat will raise the resistance of that length of wire and reduce the voltage level even more.
Also make sure your distributor hold down clamp is making a good ground connection to the distributor.. If I am running a painted clamp and distributor body I sand / scrape the paint off the contact point of the clamp and the lip of the distributor where they touch. Don’t forget that the gasket under the distributor insulates it from electrical ground. Another option is to make a separate ground wire to the distributor with a male and female spade used in it for a quick disconnect and lug rings to bolt it down at each end.
So to throw another wrinkle in talked to Lee on his engine stand -different distributor and different wiring motor did some similar weird stuff with timing ! I would think if balancer ring were moving it would not move back and that dramatic amount.
Cam thrust? would increased rpm move cam gear to retard it? Getting a new pigtail for connection but something else is weird with engine.
Man just for giggles, try a different timing light just to see.
| The Following 2 Users Say Thank You to Sun Tuned For This Useful Post: | ||
I posted last week regarding the new Proform dizzy that I just replaced in my 455 ( after the Davis unit took a crap 3 times with one coil and two modules). The Proform dizzy really likes 40 degrees at idle after warm up at the crank with vacuum disconnected. I choked it down to 30 degrees and the vacuum number off the carb went down to 12 inches. Car will run and start easily but you can feel it wants more advance.
I am going to pull off the bottom pulleys tomorrow and verify that the new SFI damper is not spun at the keyway. Other than that, it is time for a dyno to lock down what is wrong. |
To clarify, I had this engine on my test stand a little over a month ago. The owner of the engine lives near another friend of mine, and that friend put us in touch. The owner built the motor himself. We ran it on the test stand to break in the cam and check for leaks and such.
I've got plenty of voltage and larger than needed wiring. I've got a dial-back timing light that I've used on other motors. After break-in, we set the total timing to ~36 with the engine @3000-3200rpm. Upon idling it down, the timing was higher than expected. "Hmmm, maybe the distributor moved" I thought, and brought it down around 14. When I revved the motor with the timing light on, the timing RETARDED! I checked the weights, and they seemed correct and moved freely. I tried a different rotor, thinking that maybe it was binding - not the issue. My conclusion was that SOMETHING was screwy with the distributor, which was a new Summit house brand. I set his float levels, and the car was running decently. I tagged Skip in a video I took, of the motor running on my stand - smooth and proper throttle response. Owner took the motor home, and ordered the DUI. Once he had it in the car, he first had issues with the carb - turned out he had a kinked return line and carb was over-pressuring. He got THAT fixed, and now he is at the problems described by Skip. i
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
I've seen that scenario multiple times, all when the timing chain is off one-tooth.
He is running a larger hot wire tday as the Painless did look a little small.
I had to swap in one of my RobbMac starters as the ProTorque was eating up the gear on the new flywheel to even crank it. He is going to check voltage after he runs the larger wire. Also got a correct tach/Bat plug for it. Weird two distributors, two timing lights doing weird stuff! He said he did put the cam thrust plate on it when he installed and degreed the cam so not like a SBC with a roller and no thrust button. It ran smooth once we got more advance in it with the new distributor. I'll keep you all posted as what we find out. I figure a balancer outer ring slipping would not be oscillating back and forth the exactly same amount! David lives my side of town and about 5 miles from my shop. His whole street has a bunch of car guys . One with a blue Cobra kit car-I saw cruising the curvy roads near the shop this afternoon. Paul that Lee knows has a 62 and a 75 Vette and a gold "Rockford" TV show Firebird maybe a 76-that also cruises the curvy roads. And when you are on those roads 10 crotch rockets will scream past you going about 90 MPH!
DUI had not ideas. Said a bad module usually runs bad. Said could cheek ohms between green and white wire. Should be 90 ohms.
90,Ohms and steady with a little wire wiggle to check for a near break in wire..
One time I cobbled together a system using a old Hays electronic ignition mag. coil/pick up to a Crane HI6 box, I started it up and timing would retard with RPM swapped wires from mag. pick up and then it acted right .... but with so many distributors being used in this case it would appear that it's something else that is present during all observations
........... The More You Follow The Herd The Less You Can Be In The Lead .......... Last edited by Formulas; 05-05-2025 at 07:17 PM. |
