Old 05-06-2025, 08:46 AM
im4darush im4darush is offline
Default shackles for leaf springs for 72 TA
Wanting to purchase leaf spring shackles correct for a 72 TA, non rusted please
Old 05-06-2025, 09:37 AM
78w72 78w72 is offline
Are the shackles/bolts different for early vs later firebirds? If they are the same I have a set with bolts from a 76 TA, light surface rust that will clean up.
Old 05-06-2025, 10:37 AM
I'm not smart enough to know that level of detail. Perhaps someone else here will be kind enough to part with that knowledge.
Thanks for your reply! Let's see if they will work
The Following User Says Thank You to im4darush For This Useful Post:
Old 05-31-2025, 07:36 AM
Poncho Dave Poncho Dave is offline
Yes, there are different bolt spacing with the shackles. Not sure when they changed. Difference is small, like a quarter inch.
Old 05-31-2025, 09:23 AM
Wonder why the spacing would be different, or where its different?
When ordering OEM or aftermarket performance rear leaf springs or shackles or bushings, they are all listed for 70-81 and most are 67-81.
