Old 05-12-2025, 05:59 AM
jamaca85 jamaca85 is offline
Default 29.5x9 slick on a 15x7 wheel
has anyone run a 9 inch wide slick on a 7 inch wide wheel? any issues? thanks
1970 firebird, 468, e heads,
Old 05-12-2025, 09:50 AM
78w72 78w72 is offline
It will have a slightly bulged sidewall, but 9" isnt all that wide for 15x7, lots of guys run ~10" wide tires (275/60/15) on 15x7 wheels with no problems besides the more bulged sidewall than say a 15x8" wheel.
Old 05-12-2025, 02:43 PM
The issue is you won’t be using the full width of the tread on a narrower rim.
It’s not unusual for serious racers to mount 10” wide slicks on 12” rims to spread out the tread in order to use all of it.
I raced for many years with 10x28” slicks on 8.5” wide wheels and it wasn’t difficult to see that maybe only 90% of the tread width at best was being utilized.
A 9” slick on a 7” wheel ain’t that bad and ain’t that good, but sometimes you gotta run whatever fits your car.
Old 05-12-2025, 04:49 PM
grandam1979 grandam1979 is offline
Yes I have on 15x7 wheels with 9-29.5 slicks. I have 255 60 15 drag radials on 7” wheels now works great with a even pattern at 16psi
The Following User Says Thank You to grandam1979 For This Useful Post:
Old 05-12-2025, 05:45 PM
thanks guys ..I guess I will try them..thank you
