I’m running a 69 Quadrajet with divorced choke. Runs well. For a cold start, I hit throttle once to set choke then start. Starts right up and runs on fast idle. Problem is that it doesn’t stay on fast idle very long so after a short time if I hit throttle, the fast idle drops off. The choke spring is still holding choke plate closed until it hears up. I need to figure out how to adjust to keep the fast idle cam engaged a bit longer during warm up
Any ideas? Thanks |
This may help some:
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
| The Following 2 Users Say Thank You to grivera For This Useful Post: | ||
Pass side, adjust high high idle stop screw against cam, you may want a new spring in your choke stove if it's not closing choke enough.
" Long may we DRIVE !" |
Most of the spacing errors were introduced during a "forum upgrade", and they won't let me fix 'em. The point being, the fast idle SHOULDN'T be on the highest step of the fast idle cam for more than a few seconds--long enough to stabilize the engine RPM, and then you touch the gas pedal to rotate the cam to the second-highest step of the fast-idle cam. You surely wouldn't want to drop the auto trans into gear with the cam on the highest step, or idle along at 20-something miles per hour. |
