Old 05-21-2025, 07:16 AM
grivera's Avatar
grivera grivera is offline
Default Increasing Gauge Size of Alternator Battery Wire
I am installing a 150 amp alternator in my 66 Lemans. It has/will have dual pusher Spal fans, 340 LPH fuel pump. GV OD, amplifier, Dakota Digital dash, Progression Ignition. The car has a brand new M&H engine wiring harness with 12V wire for HEI and upgraded for an internal regulator.
The CVF alternator I bought may be used as a 3-wire or 1-wire. Since I have to use a 6 gauge battery wire for the alternator is it OK to attach the 3 engine harness wires to the alternator as the factory did, and add the 6 gauge wire in tandem, to the starter’s battery post?
Or should this be wired in the 1-wire configuration? If so, is it OK to run the wire to the starter’s battery post.
I’d prefer to do it as a 3-wire so I can make use of the new engine harness.
Will Rivera
Old 05-21-2025, 09:59 AM
Bill Hanlon's Avatar
I'd hook the alternator up as a 3 wire system and make sure the sense wire source is on a switched circuit somewhere down near the fuse box, not just a jumper from the alternator's sense pin to the alternator's output lug.
Speedway has a wire size chart (below) that calls for #4 wire for a 5 foot or less run at 150 amps from alternator to battery, increasing to #2 wire for 5 to 10 feet.
In the real world I'll bet your alternator will seldom if ever put out over half of its rated 150 amps.
https://content.speedwaymotors.com/D...ernator-lg.jpg
Old 05-21-2025, 11:54 AM
grivera's Avatar
The M&H harness is set for a 3-wire alternator so no jumper wire needed. Are you saying I can't connect that as normal and add the 6 gauge cable? CVF said 6 gauge is what I should use - also, I mistakenly said it's 150 amp - it is 140 amp.
Will Rivera
Old 05-21-2025, 04:27 PM
Adding the #6 wire will help. I'd make sure the two wires terminate the same place on both ends.
Old 05-21-2025, 05:36 PM
grivera's Avatar
Thank you!
Will Rivera
Old 05-22-2025, 08:35 AM
grivera's Avatar
The factory wire goes to a junction as I understand it. Not sure where it goes from there.
Will Rivera
Old 05-22-2025, 08:46 AM
Lee's Avatar
Lee Lee is offline
I agree on the 3-wire installation. Also with running the 6ga. from the alternator to the cable terminal on the starter.
That is how Mark Hamilton @ madelectrical.com suggests, and I've had excellent results from following his suggestions over the decades.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 05-22-2025, 09:01 AM
grivera's Avatar
Thanks Lee. So in your install, you kept factory style 3-wire connection and just added the heavy wire as an additional wire?
Did you have to make it a certain length so it matched that of the factory harness?
Any overcharging the battery with this set up?
Will Rivera
Old 05-22-2025, 12:56 PM
Lee's Avatar
Lee Lee is offline
Will,
MOST of what I know about electrical systems, has been gleaned from reading Mark's information. He also has a couple of small books, but excellent information in them.
Here is a link, there are actually 3 pages of info here, so be sure to click through all 3. I started typing, then realized it is better to just give you the link :-)
http://madelectrical.com/electricalt...hreewire.shtml
To answer your question, I have sometimes replaced the factory charge wire, and other times added a second wire. I route the wire up from the starter, then trim to the length I want at the alternator. I use a set of Thomas & Betts forged steel crimpers for wires up to 10ga, and have a handheld hydraulic crimper for heavier gauge wires. For power wires I typically use uninsulated terminals, do the crimp, then solder the connection, and finish with adhesive-line shrink tube.
I've had AGM batteries (XS Power and Braille) last up to 10 years, routing this way.
Something else from Mark to consider: http://madelectrical.com/catalog/tb-1.shtml
Old 05-22-2025, 01:51 PM
grivera's Avatar
Thanks, Lee - I've looked at the madelectrical site and its great info. I may get that book!
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
