Old 05-27-2025, 05:45 AM
Jeff Hamlin's Avatar
Arrow 1966 PONTIAC 230ci OHC 6 4BC "SPRINT" ENGINE.
1966 PONTIAC OVERHEAD CAM 6 SHORT BLOCK;
9782** 66 4BC, ZD CODE=M.T.
WITH FACTORY-CORRECT ONE-YEAR-ONLY HARMONIC BALANCER. SPINS FREELY.
GREAT NEAR COMPLETE PROJECT ENGINE.
CYLINDER HEAD 9782229= 1966 4BC.
Correct Valves & Double Springs.
CAM SHAFT IN HOUSING 9782218= 1966 4BC.
INTAKE MANIFOLD 9783266 &
EXHAUST MANIFOLD 9782280= 1966 4BC
Additional Parts included;
Accessory Housing.
Distributor.
Water Pump.
Fuel Pump.
Cam Housing Coolant By-Pass adaptor.
Oil Fill Tube.
Alt Bracket & Strap.
$250+ SHIPPING
(SHIPPING IS NOT INCLUDED)
I can assist with shipping.
Buyer can pick up or handles all logistics and payments. I will palletize and strap for free.
VA BCH VA.
Old 07-03-2025, 05:19 AM
Sorry, can't transport large parts to Norwalk.
Only small stuff is possible at this time.
Thx
Old 07-06-2025, 04:37 PM
Exclamation A few more parts added to the package...
...$225
Old 08-07-2025, 05:28 AM
Yes, All '66 Date Parts. Thx.
Old 09-06-2025, 01:49 PM
Talking BUT WAIT! There's more...
Here are the parts/Hardware included to make this a more complete Engine.
Date Correct Short Block with good Rotating Assembly.
Date Correct Head with All Factory Valvetrain pieces & Hardware.
Intake & Exhaust Manifolds W/ Washers, Factory correct Thickness.
Factory Y Pipe, in fair/repairable condition.
PVC Pipe, Extended on the 4BC Engines.
Crank Sprocket & Bolt.
Cam Housing Bolts, Correct length/type + End Studs.
Cam Sprocket & Bolt.
Timing Belt Backing Plates.
Accessory Housing.
Distributor.
Correct Water Pump, with Cast Impeller.
Alt Mounting Bracket & Adjustment Strap, Standard NO PS.
Starter, Correct Nose & Body.
Engine Mounts.
WHAT I DON'T HAVE;
Upper & Lower Front Timing Belt Covers.
CARBURATOR.
Carb Breather BASE.
Fuel Pump.
Cooling Fan & Pulley.
Old 09-29-2025, 07:12 AM
Exclamation SALE PENDING..
THX...
Old 05-13-2026, 05:03 AM
Sold off a few bits since sale fell off.
If you need anything for the '66 230 LMK I might have it. Thx.
