Old 05-30-2025, 08:46 PM
CatalinaMike CatalinaMike is offline
Default Mustang II or other front suspension kit
Has anyone installed a MII kit or other on their car? 72 Lemans convert I need an entire front end since this one is literally missing Thanks
Old 05-31-2025, 04:01 AM
The Mustang 2 suspension should be relegated to the same pile as the 3/4 race cam.
I would look or talk to companies like Detroit Speed or SPC to find a better solution.
Old 05-31-2025, 11:40 AM
JLMounce JLMounce is offline
The MII is similar to the short long arm setup that your LeMans would have had from the factory.
I’m not completely understanding your question though when you say the front end isn’t there. Does that mean you’re missing control arms, knuckles etc., or do you need a complete frame?
It’s some coin, but if you need a complete frame I would go straight to a Roadster Shop spec chassis. When you add up the costs of piecing a frame together with all the suspension, axle, brakes etc. the cost isn’t that much higher.
-Jason
1969 Pontiac Firebird
