Old 06-12-2025, 08:24 PM
grandam1979 grandam1979 is offline
Default 1968 radiator tank codes
Can’t find code NO any info on tanks codes? Thanks
Old 06-12-2025, 09:38 PM
OG68 OG68 is offline
Should be a radiator chart in the service manual under the engine cooling chapter. Codes are listed there IIRC.
Old 06-13-2025, 12:45 AM
What application
Old 06-13-2025, 11:35 AM
Originally Posted by Tellyshavilli View Post
What application
1968 Firebird
Old 06-13-2025, 11:47 AM
Not sure if this is what you're looking for...
Old 06-13-2025, 01:50 PM
Thanks unfortunately I don’t see NO
Old 03-12-2026, 07:51 PM
I can’t find it at all anybody ever see one with NO code?
ID:	666165   Click image for larger version
Old 03-12-2026, 11:05 PM
That would be an ON code. I did a quick search and all I found was a Camaro forum question regarding an ON tank code found on a 68 Camaro. No one there knew what it was either.
Possible replacement radiator?
Old 03-12-2026, 11:31 PM
JimFB400HO JimFB400HO is offline
The ON or NO is the tank code while the codes in the list posted is the assembled radiator codes. I have never seen a chart with the tank codes.
The codes (Camaro perspective) are explained by the CRG at https://www.camaros.org/coolingsystems.shtml#usage
I believe my '68 has the original UP code (400 w/AT) Harrison. It also has the ON/NO tank code. Was the ON used for other radiator assemblies? I don't know. Perhaps a good old radiator shop would have a Harrisom parts cross reference book??? I had my original radiator recored in '78, 86, and 11. The UP code tag/plate was missing so I had one added in 2011 during the restoration.
The Following 2 Users Say Thank You to JimFB400HO For This Useful Post:
Old 03-13-2026, 11:14 AM
Held for Ransom's Avatar
The IL and ON tanks were used on the '68 or "69 UP radiator.
So long, farewell.
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post:
