Old 06-26-2025, 05:19 PM
Tommo99 Tommo99 is offline
Default 70 firebird trans swap
Do i need to modify the tunnel to replace my stock trans with a 4l60e?
Old 06-27-2025, 10:09 AM
78w72 78w72 is offline
Sorry cant answer that... but curious why you want to put a 4l60e in a 70 bird unless it has a sbc or LS. If you want OD, a good 200r4 is a better option that will bolt right up to a pontiac engine.
Old 06-27-2025, 12:36 PM
72projectbird's Avatar
It'll fit no problem. They're essentially the same size as a TH350/400, just slightly longer in the tail shaft.
I've got a 4L80E in one, no modifications.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 06-29-2025, 12:45 PM
I have a rebuilt 4L60 sitting under my bench for a long time, im building this car for a lady and i think the 4L60 will be a nice trans, Ames have a kit that modifies the original shifter and consol so you cant even tell, thats why.
The Following User Says Thank You to Tommo99 For This Useful Post:
Old 06-29-2025, 02:04 PM
Ok, just curious. Is this a sbc engine or Pontiac?
