Old 07-01-2025, 08:57 AM
hgiv hgiv is offline
Default Clunk sound on acceleration
I'm hearing a very distinctive single tap/clunk sound when I tap the gas. It doesn't continue to make noise as you accelerate but it is very repeatable especially at very low speed. . It will also sometimes make the noise on a low speed downshift (auto th350). No vibration and the tranny shifts perfect.
There is some play at the yoke. Not a ton but seems like more than there should be?
I thought about u-joints and I will replace them just because, but after taking the drive shaft off they are moving very freely so i'm skeptical.
I replaced the tranny tailpiece bushing. It didn't look bad but I was in there so I did it. No improvement.
I'm thinking maybe the spline bushing in the tranny? Or maybe an engine mount? The mounts look OK to me.
Old 07-01-2025, 09:30 AM
mgarblik mgarblik is offline
GM used to sell a grease called spline grease through the parts department. I don't think you need this but a coating of wheel bearing grease would be worth a try. Easy enough to do. GMC and Chevy trucks had a rough time with driveline lash, clunk as you describe it. The fix for that was inserting a small "super ball", remember those?, inside the slip yoke to absorb the shock along with the grease. It actually worked! I would try grease first, then a small "super ball" if needed. If that doesn't work, you can take the drive shaft off the list as the source of the problem. If you try the "super ball", make sure you still have movement in the slip yoke when reinstalling the shaft. You don't want it jammed in tight. That could damage the transmission.
Old 07-01-2025, 09:41 AM
steve25 steve25 is offline
And your motor mounts are both good?
Old 07-01-2025, 09:51 AM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Where can you hear the sound coming from? I had the same exact issue on my car, turned out the ears on 3 out of 4 of the outboard disc brake pads were not cinched down tight to the caliper after they were installed as they're supposed to be. Because of this, they had excess radial clearance and wound clunk around every time I braked/accelerated, and would create a rhythmic clunk when coasting at lower speeds.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
The Following 2 Users Say Thank You to nUcLeArEnVoY For This Useful Post:
Old 07-01-2025, 11:06 AM
I don't think so. I didn't see any obvious problem with the mounts. It feels very "power train".
Old 07-01-2025, 11:08 AM
So is the theory that the spindle moves into the yoke and taps the end?
Old 07-01-2025, 11:33 AM
I have seen cases where the pin that holds the spider gears is loose in the differential case. Try to locate the area where the noise is coming from.
Old 07-01-2025, 05:33 PM
PontiacHO PontiacHO is offline
Check all the trailing arm or spring eye bushings. May have one that’s bad.
The Following User Says Thank You to PontiacHO For This Useful Post:
Old 07-02-2025, 03:06 AM
glhs#116's Avatar
glhs#116 glhs#116 is offline
Just to echo Steve, I had some bad clunking going into gear. Particularly reverse. I figured my driver’s side mount was bad since I have a shaker and could see the motor movement. When I got in there the mount bolts were loose and some were partially backed out. They are a pain to get to also. Worth checking.
Sam
Sam Agnew
Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it.
Ministry - Jesus Built My Hotrod
Old 07-02-2025, 04:18 AM
Maxthe222 Maxthe222 is offline
Was it not the transmission mount? My 1987 GTA had the exact same kind of situation where there was a clunk in similar circumstances, it was an easy fix as the transmission mount was perished. It went from a very noticeable clunk to completely smooth afterwards!
1987 GTA L98
1981 Y85
1979 Y84/WS6/Z49
1979 VSE F/A W72/4+1
1978 Macho #46
1978 W50/L80
1972 WS4 Lucerne Blue
1971 W66/M20/L78
Old 07-05-2025, 02:22 PM
TedRamAirII TedRamAirII is online now
Put the trans in park, and rock the car back and forth, see if you can hear it.
Bill Nye.
Old 07-05-2025, 04:16 PM
Keith Seymore's Avatar
No - Mgarblik is describing a "spline lock clunk".
The splines have radial load on them, so the driveline is bound up at that length.
Releasing the bind with grease (or the ball), or accelerating, allows the driveline to move into position - hopefully without the clunk.
K
'63 LeMans Convertible
'63 Grand Prix
