Old 07-04-2025, 03:55 PM
65madgoat's Avatar
Default Can anyone ID this crank?
Friend got what appears to be an aftermarket crank in a parts haul.
I think it has 3" mains.
Markings on it look to be:
LY0503 T4554004210-F22280
Anyone know what brand it is?
It does have serrations too.
Thanks.
ID:	653790   Click image for larger version
ID:	653791   Click image for larger version
Old 07-04-2025, 08:31 PM
mrennie's Avatar
mrennie mrennie is offline
Don't know the brand.
My guess based on the numbers is 4.21" stroke with 2.25" rod journals and 3" main journals.
Michael
1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished!
1979 Trans Am - low-buck drag car project for when I retire
Old 07-04-2025, 10:14 PM
65madgoat's Avatar
That is why I think I quickly measured too.
Old 07-05-2025, 07:49 AM
mgarblik mgarblik is offline
Need a pic of the main oil feed holes, then I can probably identify it. If it has a giant divot going across the main feed holes, it is an Eagle crank. That's their identifier. If if looks more like a stock PMD crank, but with chamferred holes, it may be a Scat. Each crank has a specific look to them.
Old 07-05-2025, 08:02 AM
Half-Inch Stud's Avatar
Eagle would be branded.
Old 07-05-2025, 09:29 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Really need more pictures. It looks like it's cast, from what's shown. It's 3.00 main, 4.21 stroke and most likely Pontiac rod journal as mentioned previously.
Go fast, see Elvis!
Old 07-05-2025, 09:45 AM
65madgoat's Avatar
No branding that I recall seeing on it anywhere ...
Old 07-05-2025, 02:56 PM
Pontiguy70 Pontiguy70 is offline
Those numbers look similar to what I remember Star Galaxy being. I think they are now RPM International. Butler sold them.
They used to have cast small journal 4.21 cranks before everything went 4.25.
https://rpminternationalinc.com/cran...80-stroke.html
Old 07-05-2025, 04:43 PM
Thanks for the pic. That looks like an Eagle crank to me. It has the giant eyebrow divot around the main oil feed. Eagle also uses serrations on the main seal area like that that needs to be polished if using a rubber or Viton rubber seal. I am not aware of other brands using a main oil feed that looks like that.
Old 07-05-2025, 10:02 PM
65madgoat's Avatar
Thanks all. I recall those Star Galaxy cranks on ebay. So figured it could possibly be one of those or Eagle of course.
Appreciate the replies!
Appears to be an Eagle Crank 4.21 stroke with 3" mains to use stock Pontiac rods.
Old 07-06-2025, 10:17 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My guess also
Skip Fix
