Old 07-11-2025, 08:52 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Default Torqstorm TS-75 SC Supercharger, Anyone?
These new bigger models seem like a real worthwhile investment if you're looking for like 750-800tq. Their TS-75 at 75mm compressor and their new compressor cover I'd imagine if I'm at 610tq N/A now on pump then on E30+ stuffing 6psi on top should get closer to 750tq for sure.
I'm Holley Hp, boost reference fuel reg and flexfuel control.
I'd figure pull 1 degree per psi and 6psi should get me my 750-800tq.
Anyone got the new Torqstorm Sc's?
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 07-14-2025, 09:52 PM
Mo's Avatar
Mo Mo is offline
I don't have one but it looks like a reasonable option. Butler has it on their site about $3600. One review below. Add an intake pipe to keep from drawing in hot air from the exhaust and add an intercooler.
Based on Butler recommendations, your 11.7:1 compression is "too high". They are recommending it be in the "9s" to 1. E-85 may help but I would defer to the real experts. Nice engine combo, must be a blast to drive.
https://butlerperformance.com/i-3164...arger-kit.html
Systems under stress fail catastrophically
Old 07-15-2025, 09:05 AM
Jay S's Avatar
Jay S Jay S is offline
I have seen someone swap out the 75 for an 84 on their newer Hemi. I believe the boost was about 12 with the 74 and just under 20 with the 84.
10.50s@125 mph with a 75. 10.10s@132mph with an 84, I think he will get into the high 9s with the 84. That is, if he doesn’t break the engine.
Old 07-15-2025, 11:58 AM
rerunss rerunss is offline
The 84 would be great on that motor. You may already know all this, but - It’s worth it to step up to a size bigger than you originally want so you don’t run out of room. Definitely run an intercooler since you have EFI. A2W will pull heat out better than A2A and you have room to package one under your hood. You can see where I put mine on my TA in this pic. I may have to change the 90* fitting. Don’t have the motor back yet to check. I cut the inner fender and still need to massage it a bit. People seem to be real happy with Torqstorm.
Old 07-15-2025, 04:53 PM
GOAT8U2's Avatar
Ya they said go T84 so it's easy 800tq on less boost. And since it's belt driven it's not like a turbo where the peak flow comes in later on bigger wheels so I'll go T84.
Since I'm E85 and maybe only need 8psi to hit 750-800tq from 610tq now I'll just ditch the intercooler. Having two cars with W2A ICs already is a huge PIA, radiator, fan, pump, lines, fittings, junction fill and sensors etc all suck. LOL
Also glad Moser made an error and gave me the 33 spline upgrade for free. Hahaha
Old 07-16-2025, 10:40 AM
Nacs Fab's Avatar
Nacs Fab Nacs Fab is offline
Getting ready to bring my 69 Bird Home for an engine swap. I have an 84mm head unit (non R) with 3.10 pulley. Chris recommended that I up my BOV to the new larger BOV. They are not so good in the marketing department so unless you join Facebook communities, little to no info on these new units is out there.
I just picked up my short block and it’s ready to hopefully make 20+ psi. 455” - started with a ‘70 400 4 bolt block filled to bottom of freeze plugs and installed billet caps and billet front cap for the extra load on pulleys. O-ringed block. Kauffman put together my rotating assembly based on some NOS 6.800” Aluminum Superods, Eagle 4.21” crank, Ross 4.155” dished pistons. Running Kauffman 80cc heads with 9.5:1 static. Northwind intake with C&S 900 Aerosol Blow Through e85 Carb with dual needle and seat bowls. I’m using belt driven fuel pump. Titan pump and Stefs 1240 pan. Hyd roller 248/254 @ .050”, .608” lift, 108ls. I hope it makes over 900. Im using a Innovators West balancer with 4 magnets, the ATI pushes the belt out of alignment so consider this - IW balancer also has 4 bolt to match the Crank Pulley.
Corey “Big Mitts” makes my 6.800” rod look small. Lmao
69 Firebird - Angry Bird
455 with 84mm Torqstorm
The Following 2 Users Say Thank You to Nacs Fab For This Useful Post:
Old 07-16-2025, 12:41 PM
GOAT8U2's Avatar
T84 $5800
Old 07-17-2025, 01:04 PM
GOAT8U2's Avatar
At big boost the o ring head is nice. I'm hoping low 10psi range on E50 and a great tune no issues on HG blowing.
That BOV is 75mm damn huge.
When you install the carb hat curious to see it on the northwind and hood clearance.
Old 07-17-2025, 04:26 PM
R 70 Judge's Avatar
Originally Posted by GOAT8U2 View Post
T84 $5800
That’s more $ than I expected
Have you considered a Vortech YSI with Luhn Pontiac brackets? We ran a YSI on my friends Buick 455 for years and it was super reliable, fast, and fun.
https://www.hotrod.com/features/ccrp...1-buick-gs-455
http://www.luhnperformance.com/vortech.html
James
1970 Trans Am
Old 07-17-2025, 04:38 PM
GOAT8U2's Avatar
Ya I had Mark do my efi like 2016.
I haven't really looked into all that but the nice thing about Torqstorm is all parts and tech support is 1 guy and I'll assume it's close in all in total price,.
SC, brackets, pulleys, hat, BOV, piping, hoses, clamps etc.
I'll check though just to see options and value. Thanks
Old 07-19-2025, 05:54 AM
Nacs Fab's Avatar
T84 $5800
Where did you get that price? I’ve not found much online and TS marketing is horrible. I pad $3300 for my Ts-84 head unit new without brackets. I’d assume that’s a kit price?
Old 07-19-2025, 12:53 PM
GOAT8U2's Avatar
Talking with Chris from Torqstorm, great communication.
Complete bolt on T84 kit, $5800.
SC, brackets, pulleys, belts, BOV, hat, filter and clamps.
Cheaper to hit 800tq this way vs bigger heads and more cubes in an Aluminum Block.
Old 07-19-2025, 03:56 PM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
how does this compare to say a procharger or vortec route?
i'm wanting to do one or the other on one of my builds after i finish my roots build.
i know there different animals but my smallish vortec v3 sci trim supercharger managed 653rwhp @ 11# on a 5.7ls1. i still have room to pulley down but im at the limit of my 70k stock short block. the power is really smooth in that car yet uncontrollable on the top end with street tire which is a blast...i been wanting to go ti trim vortec on my pontiac or f1x procharged....800hp with one of these is considerably cheaper than the others. at that level
Old 07-19-2025, 04:08 PM
GOAT8U2's Avatar
Butler shows Torqstorms and just the Procharger F1a heads no brackets.
You need a compressor that can flow enough to hit 800hp so the small SC and even the T75 was a bit small to do that without stressing the SC and possibly over spinning etc.
Street tires and torque are a mess and dangerous, I'm spinning my 295/55/15 SS and at least they'll grab after a second etc. Street R is really the only way to lay down this torque on the street but no rain and the Pro Radial is just a slick in disguise.
Old 07-19-2025, 04:42 PM
i like the bracket butler has, but theres another site called the supercharger store that has several pontiac kits with different head units. f1x was an option there.
there was a guy had a ysi crank driven kit on fb for sell. have to use an am block in order for it to bolt up tho. .
Old 07-19-2025, 04:48 PM
GOAT8U2's Avatar
I think the Butler bracket is Mark Luhn, where'd you see this bracket on Butler?
Old 07-19-2025, 05:18 PM
the only butker bracket ive seen was last year a guy had a complete kit for sale for 6500...i was kinda butthurt i missed it and it was pending when i found it.
i know my vortec seems easy on parts, do you guys think the centrifigal units are easy on parts like the turbos? or somewhere inbetween roots type violence and turbos? 8ve got it in mind that 7-800 is risky wifh my 871 on stock block....where maybee 1k is ok with a procgarger/vortec, and now torque storm
Old 07-23-2025, 09:09 AM
Curious George's Avatar
Curious George Curious George is offline
Super cool Nacs Fab!
Whitmore 462, 670 heads 10.55@125
Same with 310 E D-ports 10.12@131
498 w/single 88 8.53@158
The Following User Says Thank You to Curious George For This Useful Post:
Old 08-19-2025, 03:52 PM
GOAT8U2's Avatar
Tom on here has stated if you're near or over 800hp on a stock block go 4 bolt and keep the rpms lower to possibly relieve some stress for the block splitting. Makes sense you'd stay under 6k for sure on a 3" or 3.25" main and pray. LOL
I'm prepping for the SC, HR Parts rear bar, move shocks in to 100% vertical and see how the car hooks here. Possibly try Hoosier DR2 vs my MT SS and if the car can hook the current power plan B over the winter can happen.
Otherwise if I can't hook 620tq now what's 800tq gonna help, only ego to say it makes 800tq.
Old 03-06-2026, 05:26 PM
GOAT8U2's Avatar
Anyone do a Winter upgrade on a Torq 75 or 84?
The 84s are making crazy power on other platforms, I'm finalizing my list of things to have settled first before I jump so I'm probably early Winter 2026 now on an 84, probably 4" pulley since I want around 800tq (engine) on the stock block w 4 bolt.
