Old 07-16-2025, 12:03 PM
ros6872 ros6872 is offline
Default 68-72 Lemans GTO Horn Relay --Delco-Remy GM Part
68 69 70 71 72 Lemans GTO Horn Relay --Delco-Remy
Real GM firewall mounted horn relay--clean-- tested working-- $45 plus shipping from CT 06410.
email [email protected] or call 203-651-9990.
Enjoy real GM quality and fit
I have lots of nice 68-72 parts--www.ros6872parts.com.
Contact me with needs-- thanks for looking!
ID:	654457   Click image for larger version
ID:	654458   Click image for larger version
ID:	654459   Click image for larger version
Old 08-17-2025, 08:14 AM
Still available
Old 09-14-2025, 08:18 AM
Still available
Old 10-13-2025, 05:32 AM
Still available
Old 11-05-2025, 06:53 AM
Still availablle
Old 12-04-2025, 09:15 AM
Still available
Old 01-02-2026, 09:49 AM
Still available
Old 02-02-2026, 06:28 AM
Still available
Old 03-02-2026, 06:39 AM
Still available
Old 03-27-2026, 05:40 AM
Still available
Old 04-27-2026, 05:31 AM
Still available
Old 05-30-2026, 06:52 AM
Still available
Old 06-01-2026, 11:52 AM
1969GTO's Avatar
1969GTO 1969GTO is offline
Does the Buzzer still work while the key is left in the ignition in the off postion?
color me gone
Old 06-02-2026, 06:37 AM
this is the horn relay-- it mounts on the engine side of the firewall --usually inside a plastic cover
Its not a horn buzzer
Old 06-03-2026, 02:11 PM
1969GTO's Avatar
Horn Relay is the buzzer.
Relay should have four wires;
Red - Battery
Black - Horns
Green - Horn Switch
Pink - Key switch
The other side of the column key switch goes to the drivers door jamb switch
* See: Getting Key Buzzer Working : 02-02-2026 for more information
color me gone
Old 06-04-2026, 06:22 AM
Default relay
Oh--Ok-- makes sense since there are 4 spade lugs on this
I assume the buzzer works as it should but that is untested
The Following User Says Thank You to ros6872 For This Useful Post:
Old 07-03-2026, 07:12 AM
Still available
