Old 07-28-2025, 02:29 PM
george kujanski's Avatar
george kujanski george kujanski is online now
Default Whats up with the board again?
I'm posting here because I can't get to the main page.
George
The Following 2 Users Say Thank You to george kujanski For This Useful Post:
Old 07-28-2025, 02:48 PM
Reported to the admin.
Hopefully there’s a solution soon.
Until then start clicking on the ‘quick links’ menu and subsequently ‘today”s posts’ above, it will allow you to use multiple subforums.
Above all don’t log out or close the browser window.
Old 07-28-2025, 02:51 PM
Ogre's Avatar
Ogre Ogre is offline
Default Hope this helps ...
George, I've been playing with it for a few days. Main page has a problem (as it doesn't' seem to exist), but lower righthand corner of the page, you can pick the forum you want.
Best i can do so far,
Ogre
BTW, changed my computer link to:
https://forums.maxperformanceinc.com...prune=14&f=466
takes you to the "General Forums" page
“Man will ultimately be governed by God or by tyrants.”
-- Benjamin Franklin
- (1706-1790) US Founding Father
Old 07-28-2025, 04:08 PM
72projectbird's Avatar
The wheels are wobbling
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 07-28-2025, 05:00 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
This page has too much overlap. Not enough vacuum to pull it forward. 😁
The Following User Says Thank You to 68WarDog For This Useful Post:
Old 07-28-2025, 06:08 PM
ta man ta man is offline
Needs the timing locked out
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
Old 07-28-2025, 06:27 PM
gtorich gtorich is offline
Just curious, are you guys getting onto the site using a shortcut on the puter, when i do that all i get is a small s in upper left hand cornor. If i google the site it comes up after a few tries.
Rich
The Following User Says Thank You to gtorich For This Useful Post:
Old 07-28-2025, 06:29 PM
Do what Ogre said.
At the bottom of this page is a drop down menu to each sub forum.
Click one of them to go to the area wanted.
Bookmark one that you like and use it to come back to instead of the main front page.
Old 07-28-2025, 06:34 PM
Thank you John, that worked,
Rich
Old 07-29-2025, 08:55 AM
P@blo's Avatar
P@blo P@blo is offline
This site seems to be a target. Does it have something to do with the inflated user numbers? There is not that many people on all the Pontiac sites combined let alone here.
Any way in stopping the bot activity?
Old 07-29-2025, 09:42 AM
Thanx for the tips, guys. At least it workable using those methods.
George
Old 07-29-2025, 10:11 AM
steve25 steve25 is offline
I still can't get on from my IPhone no matter what I do.
It's going on 4 days now.
Old 07-29-2025, 11:39 AM
Try this thread I started in Lobby:
Lobby Thread
In that thread I posted some links to some of the sub-forums.
If you save them as a bookmark on however they do it on the Iphone, should be able to go somewhere.
I take it you don't see the drop down at bottom right on this page?
With my links above you should be able to go about anywhere.
(at least where I go mostly )
Old 07-29-2025, 11:58 AM
Shiny Shiny is offline
Apparently you are not alone... the forum has been below quiet for a few days.
Old 07-29-2025, 12:03 PM
I was curious, so found a link to "who's online" and concluded this is not the recent "too many guests" thing:
Name:	Untitled picture.jpg
Old 07-29-2025, 01:30 PM
I was wondering if this is a way to see if it helps PY?
Most bots may land on the main entry page at 1st, and if they get nothing may move on.
(They would have to know where a page is)
Old 07-29-2025, 03:30 PM
Yes, I just got on thru my phone by pure chance as I did a search for the name of a current string of post I recalled .
From there down near the left side bottom you can open the Todays Post section at least, but you still can’t get to any main section from there.
Old 07-29-2025, 05:15 PM
burd burd is offline
Lock site down for guests. Done.
Old 08-10-2025, 07:32 PM
I was doing this for getting on the forum, i tried this today, seems i have the main page again
https://forums.maxperformanceinc.com/forums/index.php
Old 08-11-2025, 05:19 AM
It's been back to working normal for like a week now.
