I’ve got a 69 carb 7029263 that seems to be developing an issue. Carb bogs when going from coast to light throttle. Problem is worse when engine is not fully warmed up. Once warmed up it is not as bad but still a slight hesitation at transition from idle to main circuit. Rebuilt a few years ago to Recipe 2 using Cliffs parts and manual. This bog seems new. No changes. Running on 9.5 comp 400 with 068 high lift cam. What should I look for to correct this. Thanks for any feedback
Sounds like a lean condition has developed.
The metering power piston could be hanging up either due to crap on it or in the Bore, or the air horn gasket might have expanded and or shifted and is now hanging up the metering Rods. Could also be fine dirt in the air bleeds
Besides the internals in the carb malfunctioning look at the basics such as gasket deterioration under the carb, and intake to cylinder heads gaskets. Vacuum hoses are also a culprit many times causing lean conditions. I'd be looking for a vacuum leak first, before condemning the carb.
You also have the distributor vacuum advance canister and depending upon what distributor you're using the wiring inside of the distributor on HEIs that tend to fray on the pole pieces. Also on HEI's make certain the mechanical advance weights and springs under the rotor aren't binding, or frozen.
Accelerator pump?
Beat me to it!
If it’s off idle and it just showed up I’d start there myself as long as the ignition tune hasn’t changed
The More People I Meet, The More I Love My Dogs! |
Problem solved. Thanks for all your inputs!!
Oh yes., that will make for that issue, nice find!
Some of this JB weld stuff for fixing fiberglass will get that back in action in two hours while you order up a new one. Mix it up and wait for it to start to set a good bit and then apply it .
