Old 08-24-2025, 09:25 PM
zippy's Avatar
zippy zippy is offline
Default Dizzy welding slot and deg question
I have welded up my slot on the dizzy to limit max advance. At present I have 20* mech adv. I want to add a few more. Does anyone know how much to file for x deg? Say I want 3 more deg total. Is it like .005"/deg or measurement like that?
So I don't have to pull my dizzy apart a ton to times to file and try and re file
Dan Pesonen
"If it ain't broke, modify somethin till it is"
Old 08-25-2025, 01:01 AM
dataway's Avatar
dataway dataway is offline
I designed and 3d printed this gizmo for checking mechanical and vacuum advance limits. Scale attaches where the points go, pointer slides over point cam.
I think there may be commercial items that do the same thing.
Old 08-25-2025, 09:21 AM
peters23 peters23 is offline
A little trigonometry to the rescue.
Measure/guestimate the radius (shaft center to slot end), multiply that by sin(1), which is 0.017, to get the approximate amount to remove per degree.
Its approximate because the slot is typically not concentric to the shaft, but at its own angle, which complicates things a bit further.
The Following User Says Thank You to peters23 For This Useful Post:
Old 08-25-2025, 09:29 AM
mgarblik mgarblik is offline
That is really slick! There is probably a small market for that.
Old 08-25-2025, 11:25 AM
Shiny Shiny is offline
On my points distributor, it was an estimated 0.0125" per distributor degree.
My slot length measured 0.375".
With a pin/bushing diameter of 3/16" (0.1875) I had 15 degrees at distributor, which was higher than my target.
I used a Moroso press-on bushing, with 0.25" OD. This resulted in 11 degrees advance at distributor, 22 @ crank, and I called it good.
Old 08-25-2025, 10:13 PM
70GS455 70GS455 is offline
Dollar store protractor and piece of wire
The Following 2 Users Say Thank You to 70GS455 For This Useful Post:
Old 08-26-2025, 02:56 AM
dataway's Avatar
70GS That's pretty freakin clever there.
If anyone wants the 3d print files for my creation you can find them here:
https://www.thingiverse.com/thing:5880280
