Old 08-25-2025, 11:21 AM
lrust's Avatar
lrust lrust is offline
Default PS box rebuild kit?
Anyone have a recommendation on PS box rebuild kit for 67 GTO box? works fine but needs new seals. TIA.
Old 08-31-2025, 08:48 AM
chrisp chrisp is offline
Lares corp.
Old 08-31-2025, 01:29 PM
Mr Twister's Avatar
Mr Twister Mr Twister is offline
Rockauto sells the seals you need.
Old 08-31-2025, 09:18 PM
If you are replacing just the pitman shaft seals buy the overhaul kit not just the seals. You will be glad you did if you have to take the top cover off to drive the seals out from the top. The seals will usually come out the bottom without a problem but not always. The whole kit is only about $20 more than just pitman shaft seals.
