Old 08-27-2025, 01:46 PM
Nacs Fab's Avatar
Nacs Fab Nacs Fab is offline
Default Project Angry Bird - 1969 Firebird Street Car
I posted a build thread on my 68 a while back, but have shifted gears so to speak and bought a running and driving car to build rather than remaining in Garage Jail. Let me premise it with this, I had all of the drivetrain for the 68 and was well on my way to building that car, so naturally when I sold the Body and its parts, I kept all of the drivetrain for my new purchase.
We bought a 69 Firebird that had been recently painted and the previous owner dropped in a Hod Rod Company 383 SBC that was supposedly 500hp+. Well, we drove it for a full spring/summer with the pooch of a 383, it wouldn't get out of its own way without a converter and I wasn't spending the money on it till my Poncho Plant would be installed. The car had AC that I got working and i tinkered it as long as I could stand the 383.
Car was super clean with 3.73 posi 10 Bolt and NO RUST
We sold our house in the middle of pulling the 383 and starting on the swap, so it took me a few months to get a new 30'x48' garage built at the new house. I finally brought it home. Before It left my old garage, I cut out the tubs to mini tub the car, I cut down a Rhodes Fabricated 9" ford housing and stuffed it with 35 spline strange axles, Yukon locker and 3.25 Gears. Rotor to Rotor it is 57" Wide.
The engine started out as a '70 400 Block which was 4-bolt drilled but came with 2-bolt caps. I bought a billet set of caps off marketplace and sent the block off to a machine shop and had it align bored, thrust surface cut, bored to 4.155" and torque plate honed and had them o-ring it. Block is hardblocked to bottom of freeze plugs
Kauffman did my Rotating assembly after I sent them an old pair of NEW 6.800" Superods and we built the combo around them. I wish I would have just went with steel rods, but oh well. Its an Eagle 4.12" Stroke for 3" mains and standard Pontiac journal. Ross 4.155" Pistons dished for a 9.5:1 static.
My machinist assembled the Engine and milled in clearance for the rods.
I'm getting ready to clearance my Stefs 1240 Pan to fit the Titan Oil Pump. Dropping it off this week to have a friend Tig Weld it. Ill post up more as we progress. Hope to get this car running before winter sets in so Ill be updating as I go.
ID:	656238   Click image for larger version
ID:	656239   Click image for larger version
ID:	656240   Click image for larger version
ID:	656242   Click image for larger version
The Following 4 Users Say Thank You to Nacs Fab For This Useful Post:
Old 08-27-2025, 02:07 PM
Nacs Fab's Avatar
Here is pics I got from Facebook, where another guy with same pan and Titan had to clearance his pan.
Getting ready to cut a $1000 pan to clear a $900 pump! When we weld the new patch on, Ill install a small bung over the pressure adjustment on the Titan to make on the fly adjustments without pulling the pan.
I'm waiting for S&W Racecars to ship my rack mount as I'll be installing a manual pinto rack up front. Once this kit comes in, Ill jump in and cut the old crossmember out and install the kit. I at one time had a Chromoly stub for the car, but sold it recently because I don't want to take the car any further apart!
Plan is to get the long block together so I can mock up a few things, including a 4" charge pipe with BOV and 52mm wastegate. Im going to try the wastegate thing to build boost even faster as people find its worth 60 ft lbs so why not complicate things. I am installing a TorqStorm 84mm Supercharger and I'll run my C&S 900 Aerosol Carb with mega-bowls converted to e85.
Heads are Kauffman Hi-Ports as cast 80cc and Northwind Intake.
Name:	pan modified.jpg
ID:	656245   Click image for larger version
ID:	656249   Click image for larger version
The Following 2 Users Say Thank You to Nacs Fab For This Useful Post:
Old 08-27-2025, 05:08 PM
JLMounce JLMounce is offline
Looks like a cool project. I love the limelight green!
-Jason
1969 Pontiac Firebird
Old 08-27-2025, 10:53 PM
turbo69bird's Avatar
Car looks great and happy to see it getting a Pontiac engine and turbos
960 HP @ 11 psi, 9.70 at 146.
Old 08-28-2025, 08:41 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Really cool build and fab work
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 08-28-2025, 11:12 AM
grivera's Avatar
grivera grivera is offline
Very cool - looking forward to updates
Will Rivera
Old 08-28-2025, 03:15 PM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
very cool
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
Old 08-29-2025, 12:47 PM
73LeMans's Avatar
73LeMans 73LeMans is offline
There is no way I'm NOT following this thread. Car and the work looks top notch.
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....and 2023....and 2024.....and 2025.....who am I kidding? there will be no 9s with this engine!
>>My 73 Build thread
Old 08-29-2025, 01:28 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Torqstorm 84mm, that's what I'm eyeing after I work out more bugs and suspension. I'll check back for your updates.
HR Parts N Stuff Rear Swaybay, highly recommend, Paul is making me one now and for a buddy. It'll keep the rear end level and plant the power evenly, unreal launching after install on my GN, you'll need something like this if you're gonna go 84mm, it's not a normal swaybar.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 08-30-2025, 08:11 PM
Nacs Fab's Avatar
I have a Funkhouser Anti Roll Bar kit.
69 Firebird - Angry Bird
455 with 84mm Torqstorm
The Following User Says Thank You to Nacs Fab For This Useful Post:
Old 08-30-2025, 08:13 PM
GOAT8U2's Avatar
Damn that's next level up even from the HR bar. There's some people doing thicker factory like swaybars with factory mounting locations or even ditching them but that Funkhouser is legit racecar. You'll be wheels up if you get some thick and wide stickies under there for sure.
Old 09-18-2025, 07:49 PM
Nacs Fab's Avatar
Progress on the oil pan. I had my engine builder weld a plate on the hole I made to clear the pump.
We added a 1/2” bung so I can make pressure adjustments with pan in the car. Still not sure if I can do this with a trans if the car, but forward thinking was the hope with this addition. I think he did a Fantastic job on the patch. I didn’t take a picture of the pan cut to clear the pump because it looked Exactly like Mysticmissles pan. He gave me the idea to add the bung.
I’ve been slacking but I promise I’ll get rolling soon. I just got my lights for the shop today so I’ll install them this weekend and then it’s ON!
Old 09-19-2025, 11:49 AM
R 70 Judge's Avatar
Super cool build! Love the color!
Everything Funkhouser's makes is very high quality and he's a super nice guy. I have all of his trick leaf spring stuff in my TA. He did my EFI conversion among many other things
James
1970 Trans Am
The Following User Says Thank You to R 70 Judge For This Useful Post:
Old 09-19-2025, 12:38 PM
Tom Pugh Tom Pugh is offline
I don't understand the need for adjustable oil pump pressure, please explain. thanks .
Old 09-19-2025, 01:15 PM
72projectbird's Avatar
This build is awesome! I'm enjoying following along, and can't wait to see it ripping down the track/street!
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 09-19-2025, 05:17 PM
Nacs Fab's Avatar
I ordered the Titan pump pre-set at 100psi and their pump is adjustable pressure. If I have to lower or raise it based on bearing clearance, hydraulic roller lifter issues and so on. Just nice to have the capability if it’s needed.
Old 09-19-2025, 05:18 PM
Nacs Fab's Avatar
Better photo of the pan from top down.
Old 09-19-2025, 09:08 PM
Nacs Fab's Avatar
Just realized we put the bung in wrong location. What I thought was the adjustment screw was a set screw the adjuster is a blue locknut. Oh well I’ll just keep that plugged. Geez I need lighting in my shop before I do any more work!
Old 10-08-2025, 12:24 PM
Nacs Fab's Avatar
After spending many hours getting this pan to Fit, i have it installed with a working dipstick.
I rolled the assembly over and made sure i had no clearance issues, then flipped everything over on the stand and started working on top end stuff.
I'm using an .040" set of Flatout Copper Gaskets 9012, I found that the felpro gasket is also .040" thick, so it would work for checking valve clearance. I used play dough and mocked up #1, went through several cycles and checked thickness. It had plenty of clearance since I am .023" down the cylinder due to the rods at TDC. The pic above is before testing.
I pulled the head, cleaned everything and installed all head studs and Flatout Copper Gaskets. Butler recommended that I spray them with a VHT copper sealant, so I did this as well.
Installed the heads and torqued 65, 75, 80 and 100. I then installed all of the valvetrain and set zero lash. Installed the stud girdles.
ID:	658396   Click image for larger version
ID:	658408   Click image for larger version
ID:	658409   Click image for larger version
ID:	658410   Click image for larger version
Old 10-08-2025, 12:30 PM
Nacs Fab's Avatar
I need some AN Bungs welded to my Timing Cover, I'm going 12AN on the heater hoses and 20AN on suction side of Pump, since this car will be driven. The Upper hose will be 16AN. Mocked up timing cover and Meziere HD Pump. Installed my 84MM Torqstorm and was able to trim my 4" Charge Pipe for fitment of their big BOV. All of the welding is getting done and Ill catch up on a full installation of the Torqstorm.
My next update will be mounting my front plate, fitting my Tin Indian alternator mount, C&S Belt Driven Pump off a Tin Indian Mandrel (gilmer) and mounting the Innovators West damper and mag pickup. I want to make sure this all fits before dropping it into the car.
ID:	658405   Click image for larger version
ID:	658406   Click image for larger version
