Old 08-30-2025, 07:29 PM
Default 1979-83 Wiper delay wire routing
I need clarification as to which terminal each red wire goes to on a new delay board and relay - thanks!
Name:	Delay relay.jpg
Old 08-31-2025, 11:05 AM
What I found.
I had an earlier 2 connector delay motor, these were found in pre-79 Firebirds and I believe they were originally Corvette, Caddy and other higher end models of that vintage. The electronics may be different but the relay appears the same.
This is the 1979-83 motor currently being sold, no black with pink wire.
The timing circuit board is completely different between the 1 and 2 connector setups. I also note this contact on the underside of the stamped metal base connected to the board. I assume that the 4 petaled rotor breaks the connection during each swipe?
None of my newer motors have this rotor - I do not know why, maybe when you swap motors your reuse your old rotor?
Name:	4 terminal delay.jpg
ID:	656410   Click image for larger version
Name:	1983 delay motor.jpg
ID:	656411   Click image for larger version
ID:	656412   Click image for larger version
Name:	Relay contacts.jpg
