Old 09-06-2025, 03:05 PM
dv657172's Avatar
dv657172 dv657172 is offline
Default Hood clearance issue - 71 GTO
71 GTO Hood has required quite a bit of downforce to close since I have owned it. The screws and tabs from the Ram Air inserts in the hood hit the filler panel between the nose and core support when closed and it has been this way since I owned it. (see pic of damage to filler panel where it hits)
My 72 requires some downforce on the hood to close but no where near as much and the screws and tabs clear the filler panel.
What is the issue on my 71?
Also, anyone know if a 71 GTO 400 auto with AC came from the factory with the filler panel origionally? I thought I read only 455s had them installed from the factory.
DV
Name:	Filler Panel damage.jpg
1965 GTO Cameo White, Red Interior - 389, ST300 numbers matching
1965 GTO Black, Black Interior "Post" car - 389, M-20 numbers matching
1965 GTO Silver, Black Interior 100% dedicated drag car w/1968 400(461), 16x Heads, TH400, 3.90 9" Rear 1.656 60' 7.566 90.057 (1/8th)
1971 GTO Black (orig. Quezal Gold), Gold Interior - 400, TH400 numbers matching
1972 GTO Cardinal Red, Black Interior - 455, TH400 almost numbers matching
Old 09-06-2025, 03:28 PM
Do you push the hood back first then down?
Old 09-06-2025, 03:47 PM
moneypit's Avatar
moneypit moneypit is offline
My 71 400 auto A/C car is very original and does not have the filler panel.
37 Pontiac Sedan 455 700r4
94 Firehawk Supercharged 5.7 LT1 6spd.
71 GTO base 400 A/T
97 F250 7.3 turbo diesel
Old 09-06-2025, 04:14 PM
dv657172's Avatar
Scarebird - probably not but I close it the same way as on my 72 and don't have any problem there.
I am guessing the issue is its hitting the filler panel but don't know why or how to adjust if thats the case
Thanks moneypit
Old 09-06-2025, 06:43 PM
steve v's Avatar
steve v steve v is offline
Is that a reproduction filler panel? It looks like there's a white area where it rubbed thru like it may be a fiberglass part? The original filler was a thin plastic material.
Old 09-06-2025, 06:46 PM
dv657172's Avatar
I would guess its a reproduction piece, it was on the car when I bought it and doesn't align well.
Old 09-07-2025, 04:07 AM
Kenth's Avatar
Kenth Kenth is offline
71-72 A/455 item only.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 09-07-2025, 03:06 PM
dv657172's Avatar
So I removed the reproduction fiberglass filler panel which definitely appears to be thicker than the plastic one on my 72 455 as well as incorrect it appears on a 71 400. Hood seems to close with much less effort without the filler panel installed. Also made a conscientious effort to push back a bit on the hood when closing.
Thanks for all your commets, ideas and insight.
Much appreciated
DV
