Old 09-11-2025, 03:37 PM
al63's Avatar
al63 al63 is offline
Default Fuel filler neck
Has anyone found a way to adapt or change the fuel filler neck on a 63 full size to work well with the newer smaller gas pumps nozzles? I always run into the gas pouring out all over when I gas the car up.
Are there adaptors out there to fit in the neck to help with this?
Idea or suggestion?
Old 09-11-2025, 08:00 PM
You are filling the tank too fast. The air can't get out. When it gets close to full slow down. You won't have a problem.
Old 09-11-2025, 08:37 PM
al63's Avatar
Thanks I will give that a try.
Old 09-12-2025, 10:58 AM
pfilean's Avatar
pfilean pfilean is offline
I understand the problem. Goatracer is right. Takes patience to get it to show full on the gauge.
Old 09-12-2025, 01:35 PM
al63's Avatar
Thank you. I will try the next time I fill up.
