Old 09-12-2025, 01:12 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Default Pressure wash sand blaster kits
Anyone used one of these? Does it allow you to use less sand? Man just doing a rear end I used 3 bags of sand on my sandblaster.
Skip Fix
Old 09-12-2025, 05:57 PM
grandam1979 grandam1979 is offline
I had a local guy do dustless blasting on my rearend he said he uses recycled glass. Don’t know how much he uses but it came out very nice. It was $100 with with one day turnaround.
Old 09-13-2025, 01:53 AM
indymanjoe's Avatar
i used a cardboard refrigerator box to catch most of the sand and then strained it back in to the blaster.
I am the Thread Killer!
The Following User Says Thank You to indymanjoe For This Useful Post:
Old 09-13-2025, 12:05 PM
Terry M. Hunt Terry M. Hunt is offline
X2 on the big cardboard box but with crushed glass from Northern Tool store.
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 09-13-2025, 12:14 PM
Cammer-6 Cammer-6 is offline
I just bought a cheapy($30) kit for a project.
will tell you in a couple weeks how it works out
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 09-14-2025, 10:14 AM
Skip Fix's Avatar
The time and amount of sand my plain bucket kit uses is a lot. Small spray area.
Skip Fix
Old 09-14-2025, 01:15 PM
VCho455's Avatar
VCho455 VCho455 is offline
I'm not an expert. I have messed around with some sandblasters over the years. I will say that trying different air pressure can help. Start around 40 PSI and work your way up. Air pressure is about the only adjustment the simple bucket style blaster has.
What type of abrasive are you using?
Sandblasters are deceptively simple but, the details to make them effective and efficient are complex. That's why cheap ones are $30 dollars and expensive ones are $30,000.
Water jet blasters make dust control easy. In addition they give your grit a boost as wet media is heavier than dry media so it looses less momentum between the end of the nozzle and the work surface. Which can help or hurt depending on what you trying to accomplish.
Old 09-18-2025, 06:12 PM
nh68gto's Avatar
nh68gto nh68gto is offline
Exclamation
I believe. OP is asking about Pressure washer sand blasters.
Not regular media blasters.
Send it! It’s going home on a trailer.
Old 09-18-2025, 10:10 PM
GtoFM's Avatar
GtoFM GtoFM is offline
Pros and Cons to pressure washer/sandblasters from what I've read.
Pros: Fast, easy, dustless
Cons: The pressure washer MUST have enough GPM (gallons per minute) [relate it to an air compressor, even a pancake air compressor can generate 150 psi but won't have enough SCFM to run a DA], the muddy spoils are very difficult to get out of tight cervices (TWSS)
Old 09-19-2025, 10:06 AM
Big Bear's Avatar
Big Bear Big Bear is offline
Used the 3000 psi pressure washer with the sand blast tip to blast this sub frame. Removed tar and old caked on grease better than just sand blasting but will flash rust afterwards. Used more sand than dry sandblasting. After it was broken down it was dry blasted. Normally use a pressure pot blaster at around 100 psi for heavy parts such as frames, axles and suspention pieces. One to two 50# bags of sand should do a rear axle.
ID:	657424   Click image for larger version
Old 09-26-2025, 01:39 PM
Skip Fix's Avatar
Thanks for the input guys. I wondered about the flash rust using a water blaster. Here in Houston even a dry blasted rear end flash rusts after a while!
Skip Fix
Old 10-13-2025, 09:45 PM
Formulabruce's Avatar
So, I have done plenty of dustless blasting with a pressure washer adapter. I use a 3400 psi Pressure washer, BUT, I bought a 40+ gallon.plastic juice concentrate jug, drilled hole near bottom on side and mixed my own water. Used a 12 volt pump to get it to the pressure washer.
The most IMPORTANT thing to know is " HOLD TIGHT 102" WHICH I put in the water. Its not cheap but it eliminates flash rrusting.crushed glass. Uses about 7 bags to do a bare shell.
Check humidity outside, if its over 50$ you can get flash rust even if you do it dry, so gotta get parts rinsed ( wax and grease remover) and in a place they can dry.
" Long may we DRIVE !"
