Old 09-14-2025, 06:09 PM
PLongen PLongen is offline
Default 63 Lemans 326 Dual Exhaust
what are you using for a drivers side manifold for dual exhaust?
Old 09-16-2025, 12:41 PM
67drake's Avatar
67drake 67drake is offline
I have RA manifolds on my ‘63. It took a little grinding to make the manifold not hit the steering shaft.
‘55 Catalina
Old 09-16-2025, 08:56 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
I run the RAM air manifolds and they don't hit the steering shaft. They also clear original clutch linkage with ministarter.
Old 09-17-2025, 06:26 AM
Do you have pictures?
Old 09-17-2025, 06:34 AM
https://www.ebay.com/itm/25305571981...3Avlp_homepage
Old 09-17-2025, 01:39 PM
67drake's Avatar
These are mine. My ‘69 400 is out currently, and you can see where I marked the drivers side to take even a little more material off seeing as how my engine is out anyway.
I also run a mini starter.
ID:	657314   Click image for larger version
‘55 Catalina
Old 09-17-2025, 07:47 PM
hobbygto65's Avatar
Steering shot
Old 09-18-2025, 08:53 AM
It's tight but works. what manifold is that?
Old 09-18-2025, 06:20 PM
hobbygto65's Avatar
I believe there 69 FirebIrd RA manifolds from RARE.
Old 02-01-2026, 09:38 PM
694.1 694.1 is offline
I am told that the left side A body (68-72) RA manifold will not fit this car..
Maybe it is the engine position, I did not build the car.
Should the 67-69 F body manifold to the trick?
This is a round port head motor so F body pieces will be scarce!
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 02-01-2026, 09:55 PM
hobbygto65's Avatar
Have know idea on round ports, mine are 16 D ports.
