Old 09-15-2025, 03:32 PM
PontiacHO PontiacHO is offline
Default Oil Pressure Gauge & Idiot light Sending Unit Bushing
I’ve cobbled together hardware store fittings (at oil filter adapter) to have both an oil pressure gauge line and the factory idiot light sending unit. I don’t like the look of it. Is there a simple bushing that has a male fitting to screw in (and seal up) at the filter adapter and has two female ports that the gauge and sending unit can screw into (and seal up)?
The link shows what I’m trying to achieve…
https://firstgenfirebird.org/forums/...pter%20004.jpg
Old 09-15-2025, 05:03 PM
steve25 steve25 is offline
See if you have the room to use another 1/8” hole that you drill & tap into the oil filter adapter.
Then you might only need a 45 or 90 degree fitting / adapter to get things plumbed up.
If this is too much work then you need a male 1/8” pipe T fitting block that goes to a female 1/8” at each end.
Old 09-15-2025, 05:39 PM
AG's Avatar
AG AG is offline
Use the NPT hole next to the distributor for your oil pressure gauge and you won't need any adapters coming off your oil filter housing.
Old 09-15-2025, 06:06 PM
Thanks Steve. Ordered from Amazon.
