Old 09-15-2025, 03:36 PM
melemans's Avatar
melemans melemans is offline
Default 1964 Lemans (original engine) 326 Valley Pan Crankcase Vent Gasket??
I am using a Fel-Pro PS 11488 Push Rod Cover Gasket Set. I do not recall seeing the small gasket pictured on the block or under the valley pan when I took it apart.
Question: Does the gasket go on the block between the valley pan and the block as pictured? Is it used on my application at all?
I appreciate your help.
Bob J.
Name:	Pontiac Valley Pan Crankcase Vent Gasket.jpg
ID:	657218   Click image for larger version
Name:	Pontiac Block Crankcase Vent.jpg
Old 09-15-2025, 04:58 PM
steve25 steve25 is online now
It’s not used at all for your 326.
If I am not mistaken that gasket was last used in the 370 cid motor before the 389 came out in 1959.
Old 09-15-2025, 07:54 PM
melemans's Avatar
Well, that makes a lot of sense. It didn't look like the gasket belonged. Thanks!
Old 09-15-2025, 10:45 PM
GtoFM's Avatar
GtoFM GtoFM is offline
WOW, knew one on me! I'd love to see the internals of the 370 and why a gasket was needed.
