who made this brace? i bought it off here 15 years ago...lol for the same 455 block im test fitting it on now. i have since bought a sd mega brace which is nice but i kinda like this one...seams pretty well made
https://www.krepower.com/Pontiac%20M...ck%20Parts.htm
Scroll down to find their lifter bore brace.. |
| The Following User Says Thank You to blackbird888 For This Useful Post: | ||
Looks like the KRE one to me….
| The Following User Says Thank You to ID67goat For This Useful Post: | ||
looks to be the one....i need to start looking at the kre site more often
Its a KRE brace, I own one and 2 Mega Brace's. The KRE brace is still in my tool box and both SD brace's are in service. There are very good reasons for it.
The SD brace is better in every single way. The KRE brace, you have to drill AND tap 5/16" coarse threads in your freaking block, right on top of your cam bearing bosses....... Nope, nope. It is simply held down by small 5/16 bolts, what could go wrong ? The SD brace has steel plates that sandwich your lifter bores, clamp around them. You can take a pry bar and rip that KRE brace out. Not happening with a SD brace. Its held down by eight 3/8" grade 8 bolts into steel. Not self tapped into cast iron right on top of your lifter bores. Carefully fit your aluminum blocks to your lifter bores. Put in place, mark contact points with sharpie and grind away aluminum, repeat until you get as much full contact as possible. And when you put the JB Weld on have a old hyd lifter on hand to check for lifter bore distortion. The brace can pull hard enough to make that happen. About the only thing the KRE brace is good for is if someone wanted to take a chance and slowly nickel weld the brace on a block. And that a big chance too. The KRE brace is a POS in my opinion.. Little contact area and held down by self drilled small bolts, all bad. I am no KRE hater either, I like their stuff. Just not this one. |
the mega brace i bought did come with jb weld, but ive been actually meaning to ask around on the subject of filling the gaps.
a few years back we did a pipeline gas job at work that the mating flanges had to be filled with a product called splash zone. its a Carboline product. comes in 2 one gallon cans. both parts are like puddy that you hand nead together adding some water to your glove to keep it loose. stuff is almost as strong as steel ince dried, and from what i read on google, its the same stuff moroso sells to epoxy heads when you break through while porting. anyone ever used this stuff in place of jb weld on something like this ...it was amazing on the pipe joint and i got almost a full kit of it |
Splashzone is a marine epoxy.It will setup underwater.It is also avail in smaller cans.Many head porters use it in intake ports to reshape the port.GREAT stuff.Tom
| The Following User Says Thank You to tom s For This Useful Post: | ||
glad i held onto it now. we were gonna throw it out because it expired but it looked the same as it did new so i took it home
And there is this one
https://forums.maxperformanceinc.com...ighlight=brace
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
| The Following 2 Users Say Thank You to Skip Fix For This Useful Post: | ||
You need to be careful grinding away the aluminum though. You can grind off too much to where you can tighten the bolts and get 'no clamp". I almost did with my last one but IMO they need to be fit for more surface area on the lifter bores. I did not go all the way to 40ft pounds of torque like the instructions say either. Stopped at 35 lbs with Red Locktight. They would distort a tiny bit when I went past 35 lbs and if I heard a "crack" when getting to full torque the whole block was junk. It was a little nerve wracking but it all worked out. Just remember that even with a lifter bore brace you need to pick out a safe roller. I used both methods. The "cam intensity" method where you subtract the advertised duration from the @.050 duration and you want 32 or larger split to be safe. This is from Tim G at Bullet. I had him re grind a brand new camshaft I bought on the advice from a guy who told me it was safe but it had a number of 29, not safe. New cam is 34 . And it runs great, very happy with it. While the SD Brace might not make it bulletproof I have heard of more snapped with the KRE brace then the SD. I think the more surface area and better clamping has everything to do with it. |
| The Following User Says Thank You to Dragncar For This Useful Post: | ||
That is a poorly designed brace. The lifter bores at risk of failure are on the right bank. The force that breaks the lifter bore comes from the lifter levering against the bottom of the bore, starting a crack...& history is made. The brace needs to be butted against the bottom of the bore, not halfway up the bore. I make my own LB braces that address this. I doubt epoxy would do anything because there would be enough compressibility in it to allow a crack to start....
| The Following User Says Thank You to Geoff For This Useful Post: | ||
I am happy that people are making parts for our old engines we need. But that brace has been the standard for a long time now and I do not see that changing anytime soon. Can your brace distort a lifter bore enough to make a lifter hang up if you over tighten it ? Have you taken a good look at a SD brace and fit one ? |
I think many of the SS racers using stock blocks are using the SD braces form pictures I have seen.
On a related does, anyone have first hand experience with a broken lifter bore?.... With or without a brace? ..... Any details you can provide?
One done with splash zone and a modified kre brace.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Tri power, 4speed, barn find 1966 GTO Ragtop 1969 GTO Judge RA lll, auto 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds Factory stock oval track car |
| The Following 2 Users Say Thank You to J.C.you For This Useful Post: | ||
Blew one out with the mega brace. I bought a used race stock block, could have already had a crack that I missed.
What cam was in it ? Cam card still around ?
Only heard a story from my dad. Broke a lifter bore in his comp cam solid lifter flat tappet 400 in the 90s. He doesn’t know what caused it to break. There were no braces.
| The Following User Says Thank You to Joog For This Useful Post: | ||
I have certainly seen a number of blocks break out lifter bores, but I don't have any data on if those breaks were due to particular bores that were thin castings or excessively worn to start with. I have also seen some blocks with lifter bore braces that have had failures. It seems to me, without any real proof that drilling holes and adding glue and stuff to the lifter bore area may be more of a feel good exercise than an actual structural bridge to strengthen the block. I am sure this post will be controversial. I can say we have made well over 750 HP NA on 1971-1974 stock 455 blocks and over 1200 HP with nitrous oxide injection and never broken a lifter bore. Typically crossing the finish line around 7200-7500 RPMs. Ran hard enough to break 3 blocks through the #2 main oil feed holes to the cam tunnel but never lost a lifter bore without a brace. This is all anecdotal evidence of course. Your experience may be completely different. I have worked on several Beswick old blocks that had little steel struts welded to the bottom of the lifter bores in a similar pattern to what would later become the "funny car blocks", SD-455 blocks and Ram Air V blocks. So I have to assume they did this because of prior lifter bore failures. FWIW |
Yes
