Old 09-16-2025, 08:13 AM
JEC3039 JEC3039 is offline
Default Exh Manifold Bolt Locking Tabs
How many locking tabs did the factory use - all 12 positions or just the front and back on each head or ?? Working on a 1968 F'bird 400 restoration.
Old 09-16-2025, 11:50 AM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
From a previous thread on this subject...
Name:	ex bolt locks.jpg
The Following User Says Thank You to 64-3Deuces For This Useful Post:
Old 09-16-2025, 01:27 PM
Perfect, thanks. I have that manual and missed that detail.
Old 09-16-2025, 06:41 PM
Formulas's Avatar
Formulas Formulas is offline
Are not the end holes a larger diameter as well ?.... My belief is larger holes for manifold expansion then locks to keep bolts tight from large holes and expansion cycles
........... The More You Follow The Herd The Less You Can Be In The Lead ..........
Old 09-18-2025, 07:59 AM
Formulas - I secured the manifolds before seeing your note so too late to check the hole diameters for now. Next time manifolds are off the car I'll try to remember to report back...
Old 09-18-2025, 09:21 AM
steve25 steve25 is online now
I know the locking tabs where done away with by 75 and washers where exchanged.
This could have even had taken place back earlier as in when the low comp fully set in by 1971, but I have no definitive proof of that due to the circa of manual’s I have.
Old 09-18-2025, 10:07 AM
64-3Deuces's Avatar
On cast iron manifolds the outer holes are larger to account for expansion and contraction (thermal cycling). I researched this when I noticed the larger outer holes on my ram air manifolds. There is a thread or two about this subject on this forum.
Old 09-18-2025, 10:37 AM
And the above is a darn good reason when running exh manifolds to use the factory steel gasket only and with a coat of antiseize on both its sides .
