Old 09-24-2025, 11:58 AM
Dick Boneske's Avatar
Default Console for '64
We finally installed a console in our '64 GTO. The transmission is manual.
How can I determine if the console is a '64 or '65? Even though the color between the ribs and the sides adjacent to the shifter is black, I believe this one may be a '64. Did all '64's have the dark aqua paint between the ribs? How about the sides? I believe that color is the same as the heater control bezel.
I do not have the light socket assy. with switch that controls the console storage compartment. The interior light on the rear of tha console does not have a switch.
If anyone has pictures of the light socket detail, I would appreciate seeing them. I will post pictures if needed
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 09-24-2025, 02:34 PM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
Pictures of my 64 NOS top plate. The paint color on the 64 is the gray/green and it matches the gray/green on the heater control. I have a basically NOS heater control for comparison. I believe these colors were originally more "green" but have faded over time. There is no paint on the sides. The shifter escutcheon on the 64 was cast in place and on the 65+ it was a separate piece screwed in.
As for the courtesy light switch the restoration manual indicated this was used on some 64 and 65 models with automatic trans only.
Edit: If you mean paint on the sides other than just between the ribs, then yes as shown in the pics.
ID:	657627   Click image for larger version
ID:	657628   Click image for larger version
The Following User Says Thank You to 64-3Deuces For This Useful Post:
Old 09-24-2025, 06:33 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default 64 dash Heater control
Just for color comparison. Original paint.
Name:	64 GTO dash heater control faceplate.jpg
Peter Serio
Owner, Precision Pontiac
Old 09-24-2025, 10:04 PM
64 had the molded cup . Dead giveaway.
65-66 had the removable cup with a raised flared edge around perimeter.
Old 09-24-2025, 11:28 PM
bill ryder's Avatar
bill ryder bill ryder is offline
BVZ X2!
"Bill"!
Old 09-25-2025, 05:18 AM
Jeff Hamlin's Avatar
Thumbs up A few more pics for reference...
Old 09-25-2025, 10:38 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
????? ….. anybody that’s been around the first GTO (1964) should know the manual shift console and color by now.
Here’s the gorgeous ‘64 that Jeff Hamlin sourced his above photos from.
ID:	657686   Click image for larger version
ID:	657687   Click image for larger version
ID:	657688   Click image for larger version
ID:	657689   Click image for larger version
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 09-25-2025, 11:36 AM
Now I know our console is a '64. Will need to paint between the ribs with the same paint I used for the heater control and dash chrome ribs.
Does anyone have info on the light socket and switch for the console door?
BONESTOCK GOATS
Old 09-25-2025, 02:26 PM
I always thought they used the same color in the cup , as on the topside.
Is it supposed to be a grey'er shade inside the cup instead ?
Old 09-25-2025, 02:28 PM
That's great news , they have Always been tough items without screw holes or busted cups.
Im thinking Ames probably has the wiring/light/switch components.
Old 09-25-2025, 07:41 PM
Thumbs up
Half right, the first two images are from a '64 Le Mans that I viewed while at the GM Nationals in PA several years back.
Old 09-26-2025, 09:03 AM
bill ryder's Avatar
Ames definitely has the correct socket, switch. Not the best of quality but!!!!!! Just don't drop the lid on the switch or else.........
"Bill"!
Old 09-26-2025, 12:29 PM
propuckstopper propuckstopper is offline
Do any of these pictures help you? I just went through this process after restoring the original console in my '65.
Name:	1965-1967 Console wiring.jpg
ID:	657761   Click image for larger version
Name:	1965 GTO Console Assembly.jpg
ID:	657762   Click image for larger version
Name:	GTO Center Console Wiring.jpg
Old 09-30-2025, 12:24 AM
xgoater's Avatar
xgoater xgoater is offline
Dick,
I think this should help if I understand your question correctly.
https://www.bing.com/videos/rivervie...=0&FORM=VMSOVR
1. You can get the socket assembly from several vendors, including our host:
https://www.amesperf.com/parts/20965/
2, Disconnect the orange wire from the socket. The bulb will come loose as the wire prong end also acts as the keeper for the bulb tab. To remove the orange wire from the socket, you have to take a mini flat blade screwdriver and through a slot in the housing, GENTLY AND CAREFULLY push the metal hook/bulb connector inward just a little bit so it releases from the housing. The originals had a little tab to hold it in. I assume the repros are the same.
3. Install the socket from the top. Insert in hole and push down until clips engage.
4. Connect orange wire from underneath the console into the socket and replace bulb.
5. Splice new orange wire into existing harness under console. Here's a picture of the console harness so you can see where the two orange wires go from the connector to the box light and rear courtesy light.
https://amesperf-parts.s3.amazonaws.com/M12275.JPG
Hope this helps.
Terry
Old 09-30-2025, 08:40 AM
Rich-Tripower's Avatar
I wish our 64 had a console. It just looks better. But it was never built that way so we are keeping it original. But they look great, so much more useful than the console in my 65 Malibu SS which is just a big hunk of metal, no storage bin.
