Old 09-25-2025, 12:17 PM
sportylemans sportylemans is offline
Default Can flex plate be installed backwards? Th350 install
Can the flex plate be installed backwards? Took the flex plate off to check if oil leak was coming from rear main seal or oil pan when I was replacing my th350. Totally forgot to mark it.
Mostly done installing it and it dawned on me about not marking. Checked converter to flex plate clearance and I’m a hair over 3/16” so I added grade 8 washer after I micd them so I’m a hair over an 1/8” now, but under the 3/16”
71 350 with stock flexplate and th350.
ID:	657693   Click image for larger version
Old 09-25-2025, 12:55 PM
You can’t install it backwards.
There’s one hole in the crank and flexplate or flywheel that’s drilled offset so you can’t install it backwards, this is also to keep the flywheel or flexplate clocked for balance purposes.
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 09-25-2025, 01:20 PM
Thanks, appreciate the quick reply. Back to the garage now.
Old 09-25-2025, 03:37 PM
srmmmm's Avatar
srmmmm srmmmm is offline
I think you've got it on backwards. I would expect the darker, oil & dirt covered side to be facing the engine where you would have seepage from the rear seal.
Old 09-25-2025, 04:14 PM
Formulas's Avatar
Formulas Formulas is offline
Noooope... its on right.. There is another tell in plain view that has not been talked about yet..
........... The More You Follow The Herd The Less You Can Be In The Lead ..........
The Following User Says Thank You to Formulas For This Useful Post:
Old 09-25-2025, 04:30 PM
Is it the second pic flexplate teeth where the starter engage?
Old 09-25-2025, 04:52 PM
The big center hole is mushroomed out towards the converter and won't fit correctly the other way.
The Following 4 Users Say Thank You to Goatracer1 For This Useful Post:
Old 09-25-2025, 08:01 PM
stevep's Avatar
stevep stevep is offline
It's possible on a Chevy, but not on a Pontiac
The Following User Says Thank You to stevep For This Useful Post:
Old 09-26-2025, 02:42 PM
srmmmm's Avatar
I have seen a dimple on some factory ones that if mounted backwards, would create an obvious wobble appearance because the plate would be tilted on the crankshaft flange. But the angle cut on the teeth look like they're facing the wrong direction too.
Old 09-26-2025, 03:23 PM
Formulas's Avatar
What i was referring to is the angle cut on the teeth... ( plain view ) At first glance and reasoning one would think the angle cut should be for engagement, .... Towards the front but in fact when installed correctly they are facing the rear of the car.... I researched / asked why a long time ago forget who or where i got this info from but the angle cut reason was for a easier dis'engagement of teeth although i don't foresee a big problem without the angle cut. ... Engineers must have seen something and that was the answer that worked at that time..
Old 09-26-2025, 04:52 PM
Gary H's Avatar
Gary H Gary H is offline
A Pontiac flexplate can't be installed backwards. The bolt pattern won't allow you to get all 6 bolts in.
Old 09-26-2025, 05:06 PM
I'm pretty sure you can only get one bolt in if backwards.
Old 09-29-2025, 11:31 AM
zippy's Avatar
zippy zippy is offline
The bevel on ring gear
Dan Pesonen
"If it ain't broke, modify somethin till it is"
Old 09-29-2025, 06:08 PM
Thanks everyone, I’m back on the road. Still making some adjustments to the shift linkage though.
One more quick question. Factory console, adjusted the lockout, NSS and shift cable. All seems fine, shifter locks in all positions except low, no click for that. I want to say that’s normal, but wants to verify?
Old 09-29-2025, 06:39 PM
P@blo's Avatar
P@blo P@blo is offline
The new Shina plates do not have the flare on the hub to make it as obvious when bolting down. I would call it more of an offset. Some guys have even drilled out bolt holes to put it on wrong
When in doubt chipped teeth to the front and the forever perfect bevel to the rear...😎
