Old 09-25-2025, 02:37 PM
michaelroy's Avatar
michaelroy michaelroy is offline
Default Turn sig. switch
1965 non tilt 4 speed console shifter.
Is there a way to test the switch to determine if good ??? My turn sig. quit while I was testing all lights, after replacing the original voltage regulator.
Old 09-25-2025, 04:58 PM
Just use a test light and go through the different wires.
Old 09-26-2025, 10:25 AM
michaelroy's Avatar
Which one are suppose to be hot?
Old 09-26-2025, 09:32 PM
I don't know which color goes where. There should be 1 hot one with the key on. When you turn the switch for left there should be 2 more. When you switch right there should be 2 different ones come on and the other 2 should go out.
Old 09-30-2025, 10:10 AM
michaelroy's Avatar
Default Turn sig.
Thanks a lot that really helps. currently only the black wire is hot going to horn.
I'm assuming the switch is bad.?
