1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 10-03-2025, 01:27 PM
V-Ped V-Ped is offline
Default 3rd gen alternate VIN locations
I am trying to determine the VIN of an 83 Trans Am. Water leak completely corroded the number at the base of the windshield. A sticker on the door jamb is completely illegible. I had read that a possible location was on the bulkhead around the rear hatch latch, but I found nothing there.
Any suggestions?
70 Goat
74 Ventura
63 Cat
56 GMC
et al.
Old 10-03-2025, 05:46 PM
cmoc-bob cmoc-bob is offline
The front body support rail, passenger side should have the VIN stamped in.
RPO tag too (glovebox)
Old 10-03-2025, 05:54 PM
So, under the fender......part of the unibody support structure
Old 10-04-2025, 08:45 AM
Thanks for the reply, Bob. The “glovebox” is just a vinyl pouch attached to the face of the dash. Do you know if the fender has to be removed to see the part of the support structure with the number?
70 Goat
74 Ventura
63 Cat
56 GMC
et al.
Old 10-04-2025, 10:06 AM
I would think loosened up, not removed.
You should have a RPO sticker, maybe in the back hatch area. Pretty sure you have a small opening for the spare tire.
Also - underneath the center console lid, my '84 has it there.
And - the RPO list might of not started until 1984. So '83's might not have it (RPO sticker)
Old 10-07-2025, 09:58 PM
Thanks again. I also found out the data plate (cowl tag) is not on the cowl but on the radiator support. Car is at a friend’s house and I have to get with him to check it out.
70 Goat
74 Ventura
63 Cat
56 GMC
et al.
