Old 10-12-2025, 07:56 PM
blue71ta's Avatar
blue71ta blue71ta is offline
Default Valve Lash on a '71 455 HO
I've got a '71 T/A with the 455 HO engine. I'm running a Comp Cams Xtreme energy cam with matching lifters, springs, retainers, locks & pushrods.
I'm using the big block chevy style rocker studs to make the valvetrain adjustable.
Looking for opinions on what to set the valve lash at. Zero plus 1/4 turn, 1/2 turn, 3/4 or other? What do you guys usually do on an adjustable valvetrain?
Old 10-12-2025, 08:29 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
I don't remember... 1/2 or 1 turn.
So long, farewell.
Old 10-13-2025, 04:05 AM
Kenth's Avatar
Kenth Kenth is offline
If the plunger in the lifter has the std 1/8" travel i would use 1 full turn from zero.
That would place the plunger about halfway into the lifter.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 10-13-2025, 09:40 AM
78w72 78w72 is offline
What did the instructions for the lifters say to adjust them at? Different lifters can have different adjustment amounts... best to read & follow what comp says to adjust them to or call comps tech line.
Old 10-16-2025, 10:11 AM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
Default valve lash
Make sure to Soak the lifters overnight in oil.
Follow the firing order.
Turn the push rod with fingertips until you feel the drag change.
1/2 turn and that should be good.
Loser the better without clatter.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
The Following User Says Thank You to skunkwerks For This Useful Post:
Old 10-16-2025, 10:21 AM
Norwood's Avatar
Norwood Norwood is online now
I could not of said it better.
The Following User Says Thank You to Norwood For This Useful Post:
Old 10-20-2025, 06:35 PM
blue71ta's Avatar
Thumbs up
Thanks for the input. I did reach out to Comp Cams also, but am waiting on a reply. Figured the Pontiac specialists here would know what's up.
Old 10-21-2025, 11:11 AM
Better to call their tech line, emails can take a lot longer. Or if you have it, look at the instructions that came with the lifters.
Im sure 1/2 past zero lash is a good ballpark or might be the correct setting... but different lifters can & do have different adjustment specs, even the same brand can have different adjustment based on the type of lifter.
Old 10-21-2025, 06:22 PM
I always used zero lash plus 1/2 turn.
Same procedure slunkwerks noted in the earlier post.
The Following User Says Thank You to poncho-mike For This Useful Post:
