Old 10-13-2025, 08:46 AM
66_Cat_Jon 66_Cat_Jon is offline
Default Any recommendations for the best oil pan gasket?
I just attempted to install my old steel oil pan onto the engine I'm assembling. I had installed the bolts just snug to let the silicone dry. A couple of hours later I came back to tighten the bolts to final torque and they squeezed the gasket out and in some places split it. The oil pan as I said is old and the bolt holes are bulged. I'm going to try to address that some with a hammer, etc to see how flat I can make it. The gasket I used was the fiber type from Butler. Have any of you had better luck with any particular brand or type of gasket on old, stock steel pans?
Philosophy on Life: Try not to be an A**hole.
Old 10-13-2025, 08:58 AM
grivera's Avatar
grivera grivera is online now
Many here use the BOP one-piece oil pan gasket. https://butlerperformance.com/i-2445...86vq5_sFEV97Lt
I will say, the method of installation is just as if not more important than the gasket used. A regular Felpro set will work great. One area that requires extra work is the rear main cap. Using a thick strip of cork, glued to the cap will work well.
Make sure the pan’s bolt holes are flat - overtightening a squishy gasket leads to distortion of the pan rail and then it won’t seal right.
Do a search here on that topic as it’s been beaten to death.
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 10-13-2025, 10:52 AM
Nacs Fab's Avatar
Nacs Fab Nacs Fab is offline
BOP one piece for me
69 Firebird - Angry Bird
455 with 84mm Torqstorm
The Following User Says Thank You to Nacs Fab For This Useful Post:
Old 10-14-2025, 04:47 PM
Dragncar Dragncar is offline
None, Grey RTV and a cork around the cap. No leaks.
Old 10-14-2025, 10:52 PM
ZeGermanHam's Avatar
I installed the BOP 1-piece gasket on my engine over 3 years ago and it has not let out a single droplet of oil. The underside of my engine has stayed spotless and leak-free, and I am able to examine very closely and regularly since I have a hoist. Definitely a fan of that BOP 1-piece oil pan gasket.
1998 BMW 328is (track rat)
