Old 10-13-2025, 08:52 AM
East East is offline
Default 1969 Firebird Throttle Cable Specifics
When ordering a throttle cable, is there a specific condition to follow so that the cable end will be able to attach to the carb linkage correctly?
I just installed a new throttle cable bracket that replaces the one I had that was for an A body. I had cut off the part of it that fits to one of the manifold bolts, and I hogged out the hole that bolts to the top of the manifold.
Now that I have the correct bracket, the throttle cable appears to have extra length which may not allow the throttle to be fully opened.
I have found that Ames has a 2 BBL cable at 19" and one for 4 BBL at 19 5/8 inches. This adds to my confusion being that I have a 4BBL.
Name:	Throttle cable bracket.jpg
ID:	658602   Click image for larger version
Name:	new bracket.jpg
Old 10-13-2025, 09:50 AM
JLMounce JLMounce is offline
This apparently was common on Firebirds. The engines were "detuned" slightly by having a throttle cable that did not allow full wide open throttle operation. You'll likely need an adjustable throttle cable like a Lokar unit to cure this.
-Jason
1969 Pontiac Firebird
Old 10-13-2025, 05:23 PM
The repro cables are awful, they give the throttle a corse rough feel.
Old 10-14-2025, 04:03 PM
Default It seems to be that two rights also make it wrong
I keep trying to correct my past mistakes by replacing incorrect parts with the correct parts.
The more I try to make it right, the more it causes things to be wrong.
I will go through my bin of parts that I removed to find out if I happen to have a throttle cable that may be the correct one.
Thanks for the replies and insight.
Old 10-14-2025, 05:07 PM
I had a repro cable on a 69 LeMans 350 HO (same cable as a GTO). Always had a notch, rough throttle tip in, sticky spots in the pedal travel.
I ripped apart the carb three times, gasket matched the gaskets on the carb ant the carb to intake gasket, lubed and cleaned the linkage around the gas pedal and the cable repeatedly. Nothing worked. On a whim I bought a correct used cable on eBay for like $20, problem solved instantly.
The repo cables have a course rough cable inside that scrapes and catches because of the burrs and rough surface. The factory unit had a silky smooth cable.
Old 10-15-2025, 01:31 PM
Default I will also look for an original
This will probably be a hit and miss not being able to determine if the cable is actually a factory original.
Thanks for the heads up.
Old 10-15-2025, 05:36 PM
rohrt rohrt is offline
I fought this stuff years ago with my 68 FB. This is what I recall.
The F4 bracket I got from The Parts Place didn't match an original one I had. Not sure if they changed between years or if they made a F4 for both A and F body. The parts place one needed a bolt with a small stud on top. The original one I had didn't. All else looked fine.
Finding a good 4lbb cable was really tough.
When i tested the carb opening it was not opening fully. I had to remove the pedal assembly and do some bending. That was not fun with the motor in.
Old 10-15-2025, 05:55 PM
The second picture in the first post is the one that you are talking about with the upper bolt and the lower manifold bolt.
The first picture is the one I just took off my car with the lower bolt hacked off.
I had taken a 400 engine out of a 68 or 69 GTO. The engine was a 1973 400.
That's how I ended up with the wrong pulleys and brackets.
I just fixed my pulley alignment issue. Thank God I saved the other (my original 350 ) balancer with pulleys. I didn't use it because I dropped it and made it wobbly.
Anyway, I will have to work out the cable length issue. I was by myself so I didn't press the gas pedal to the floor to see what I have at the carb. linkage.
Thank you all.
Old 10-15-2025, 07:29 PM
Hey East, do you think we have members with the handle West or South?
Yours truly,
North
Old 10-15-2025, 08:05 PM
Default No Sir
I did not find users with those names here.
My excuse was how I named computers in my house long time ago.
Old 10-15-2025, 09:00 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Yours truly,
North
No pure West or South. But there is a West Coast GTO.
So long, farewell.
