Old 10-14-2025, 12:07 PM
grivera's Avatar
grivera grivera is offline
Default 66 Lemans - Carpet Cutting Under Console - Automatic Trans
I'll be installing an ACC carpet in my 66 Lemans soon - it has a factory automatic transmission. Did the factory mount the shifter assembly on top of the carpet? Any other tips for navigating that area?
ID:	658661   Click image for larger version
Will Rivera
Old 10-14-2025, 12:12 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
If memory serves it’s mounted on the metal brackets directly, I think it gets its ground for the light that way maybe?? In order to make the carpet fit well I had to cut it out for the shifter and then overlap it to fit better but it’s been awhile
The Following User Says Thank You to ponchjoe For This Useful Post:
Old 10-14-2025, 04:24 PM
grivera's Avatar
Good point on the ground - thanks
Will Rivera
Old 10-14-2025, 04:57 PM
Jeff Hamlin's Avatar
Thumbs up
Not as much for grounding as much as it is for stability.
Also, remember there are plastic spacers between the shifter bracket and the floor.
