Old 10-14-2025, 03:58 PM
Tomaso Tomaso is offline
Default Custom 9” Rear end for full size Pontiac?
Who can do a custom Ford 9” rear for a 66 Bonneville? I tried contacting some guys, but they keep trying to sell me the GM B body rear end setup in which I told them it’s not the same, and they said they weren’t able to help…
Mike
Old 10-14-2025, 11:21 PM
indymanjoe's Avatar
quick performance can handle that.
I am the Thread Killer!
The Following 2 Users Say Thank You to indymanjoe For This Useful Post:
Old 10-15-2025, 04:01 AM
What does the rear end fit that they are trying to sell you? A Bonneville is a "B" body. Tempest/Lemans is "A" body.
Old 10-15-2025, 07:01 AM
The GM B body option that fits the Impala. Fits: 1965-1970 Impala, Biscayne, Bel Air
But not Bonneville, Catalina, etc.
Mike
The Following User Says Thank You to Tomaso For This Useful Post:
Old 10-15-2025, 04:36 PM
RocktimusPryme's Avatar
Any of the big companies can probably do it, they are just going to require you to either tell them exactly where any mounts need to be based off your factory rear end, or give you one with the length you want and expect you to put on your own spring pockets etc.
I know Quick Performance will sell the rear ends with the brackets tacked in place so they can be easily removed if you need to relocate them.
The Following 2 Users Say Thank You to RocktimusPryme For This Useful Post:
Old 10-15-2025, 04:42 PM
You’re going to have to buy a bare housing in the correct width.
Then cart it over to your local (or not so local) chassis fabricator along with your original housing for them to copy the mounts or possibly remove the ones from your original that could be transferred.
Get out your wallet.
Any unpopular rear end such as yours won’t be in any aftermarket supplier’s listings. It makes little sense for aftermarket rear end manufacturers to have jigs and blueprints for rear ends that they likely won’t even sell 10 of in a decade.
Old 10-15-2025, 09:15 PM
I'll agree with b-man. Measure your original rear axle assembly from backing plate to backing plate then find what Ford product comes within plus or minus 1 inch. Cut off the Ford mounting points and grind smooth. Carefully remove your mounting brackets and have someone weld them to the Ford housing. Just be careful locating them correctly. It is really not hard. The guy 2 houses down from me welded mine in his driveway after I marked the correct locations. You can then order whatever center section you require. Also much cheaper.
The Following User Says Thank You to Goatracer1 For This Useful Post:
Old 11-03-2025, 08:26 PM
When I talked to Quick Performance about building a 9” for my ‘64 Cat they wanted the original housing to ensure the mounting bracket were in the same location on their housing. I don’t know where you are located but Iowa is one state over from me( Indiana). Shipping a bare housing could get expensive.
Dr. Thomas Sowell
Old 11-03-2025, 08:27 PM
B body Pontiac rear housings are wider than the rest of the GM B bodies.
Dr. Thomas Sowell
Old 11-07-2025, 02:36 PM
AROWHED's Avatar
AROWHED AROWHED is offline
Send a message via Yahoo to AROWHED
Another option is cut your 66 Pontiac axle housing tubes off (keeping all their attached brackets) and weld the pair to the tubes of the center section of your choice. I'm running a 63 Pontiac 9.3" center section with 65 axle tubes welded to it, still retaining their 65 control arm and coil spring brackets. This did require using swedged tubes and heim joints for the upper control arms, as the 63 housing brackets are farther apart than the 65, actually a plus as I wanted adjustable uppers anyway. Axle shaft length and spline count must be considered before any cuts are made, in my case it was easy as 63 and 65 are both 31 spline. This method also allows narrowing, but then new custom axle shafts are mandatory and creates lower control arm geometry issues that must be addressed.
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool
The Following 2 Users Say Thank You to AROWHED For This Useful Post:
