Old 10-16-2025, 04:30 PM
Gary H's Avatar
Gary H Gary H is offline
Default Unusual speedometer gear housing
Just started working on a customer's 72' Bonneville. The car is very original with it's 455-2 bbl engine and long shaft turbo 400 transmission. Found it has this speedometer housing with a wire going to it, along with the traditional speedometer cable. Is this a speedometer speed warning option? I've never seen one in 40 years of working on Pontiacs.
ID:	658765   Click image for larger version
ID:	658766   Click image for larger version
ID:	658767   Click image for larger version
Old 10-17-2025, 07:47 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
That is the transmission controlled spark speed sensor. It works in combination with the solenoid on the intake and temperature sensors on the engine to keep vacuum advance off of the distributor under 25MPH or not above a certain temperature\warmed up (the temp changed year to year from 1971-1974). 1972 only thing on transmissions from GM cars.
The Following 2 Users Say Thank You to Ben M. For This Useful Post:
Old 10-27-2025, 09:40 PM
Gary H's Avatar
Well, that's a new one for me! Never heard of that before. Learned something new!
