Old 10-19-2025, 07:33 PM
Mark66 Mark66 is offline
Default 1966 Big Pontiac headlight switcvh
Looking for a NOS/used headlight switch for a big 1966 Pontiac, PN 1995138. Also fits 1963 T/4 - T/8 and 1967 Catalina, Executive and Bonneville's and maybe others. Do not need knob and attached rod. Would also buy a used switch connector for this headlight switch. Trying to stay away from the new headlight switches as they seem to frequently require the use of jumper wires.
Old 10-19-2025, 09:21 PM
694.1 694.1 is offline
You are wise to avoid the "counterfeit" switches, the original Delco were excellent.
Very easy to clean up & lube, they used white lithium grease from the factory.
They had a wide interchange in '66, easy to find.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 10-19-2025, 09:56 PM
Redpiston Redpiston is offline
If you are near PHX, when I was there about 18 months ago, Desert Vally Auto had several B bodies to pull from.
