| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
There is a neat article of a 'survivor' 1966 Beaumont SD396 in the fall-2025 issue of 'Musclecars; Bone stock & modified'.
This car apparently will be at the upcoming MCACN. I reached out to members of 'Canadian Poncho' who specialize in this subject matter (they are all about Canadian built Pontiacs, under which Beaumonts and Acadians fall) and I was told that the transmission in this car is a 'T-16' Borg Warner three speed. I had previously recorded that Chevrolet (and Canadian Pontiac's) used the 'T-16' for 1965 through 1968. I have been trying for some time to compile three speed information to make sense of it all - because this is information which I believe is being lost. One of the things that doesn't help to clarify GM's components is the use and re-use of UPC/RPO's; Question: Is 'T-16' a GM product code? I am asking this because it reads (from overlap in my own notes) that the 'T-16' might be an alternate code for Borg Warner's 'T-85'. I found the following picture of what is said to be a T-16: ![]() (image attached incase the hotlink dies.) This image appears to match what I have found about the T-85, which I am understanding was the basis of the T-10 four speed (The T-85 is even referenced as the precursor to the T-10 in the "Muncie 4-speed" book put out several years ago by Car-Tech). It seems that google searches are becoming less and less relevant, because I continue to be unable to find information of any substance; I couldn't find any any information of substance regarding a BW T-16. Thanks in advance to anyone who might be able to offer information to give me some clarity.
1970 Formula 400 Carousel Red paint on Black standard interior A no-engine, no-transmission, no-wheel option car. Quite likely one of few '70 Muncie three speed Formula 400's left. 1991 Grand Am: 14.4 @ 93.7mph (DA corrected) (retired DD, stock appearing) 2009 Cobalt SS: 13.9 @ 103mph (current DD; makes something north of 300hp & 350ft/lbs) Last edited by unruhjonny; 10-20-2025 at 05:39 PM. |
I would think that is a B/W code.
It is not a Pontiac code I don't think. It would probably be like M13/M-13? I also thought the 3 speed was a Ford Top-loader? (Pontiac HD anyway)
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
it reads as though Pontiac used the Borg Warner T-85 from 1958-1964 and then went to the "Dearborn" (read: Ford) top loader for 1965-1969.
M13 is the UPC/RPO for a HD-3spd and not an indicator of the unit used. I am expecting the T-16 to be a different unit than the T-85; But look at that image of the T-16; It absolutely looks like a T-10; except the T-85 is cited as the precursor to the T-10. Information on this 'T-16' is really hard to come by... Maybe T-16 was a BW code for a GM variant of the T-85?
1970 Formula 400 Carousel Red paint on Black standard interior A no-engine, no-transmission, no-wheel option car. Quite likely one of few '70 Muncie three speed Formula 400's left. 1991 Grand Am: 14.4 @ 93.7mph (DA corrected) (retired DD, stock appearing) 2009 Cobalt SS: 13.9 @ 103mph (current DD; makes something north of 300hp & 350ft/lbs) Last edited by unruhjonny; 10-20-2025 at 05:38 PM. Reason: I keep mistyping T-86 instead of T-85 |
M-13 was used by Chevrolet to designate the HD 3 speed transmission. Borg Warner in this instance. And since the Beaumont used a Chevrolet power train, I'd expect it would have the Warner trans.
https://chevellestuff.net/1966/options.htm 1966 Beaumont specifications and 66 Chevelle transmission option codes attached
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
ok great.
That tidbit might have a piece of the puzzle. Unless my own notes are mistaken: Warner T-85
Warner T-16
Assuming that the 'T-16' isn't just a code of a variant of the 'T-85' that (Borg) Warner manufactured exclusively for GM; Is it possible that the 'T-16' is an evolution of the 'T-85' which differed in being fully synchronized? I am seeing that Warner made (at the least) T-84, T-85, T-86, T-89 - and that's just the T-8x units I have in my file; Like I said, I am in earnest trying to compile and make sense of all this... It appears that the T-84/T-86 (& T90/T96) were from a different line of transmissions; But one source that I found (which I am incline to think is mistaken) suggested that the T-86 started out with a side load case, then changed into a top load case in the mid 1950's ... ?? It also appears as though the T-85/T-89/T-16 might be from the same line - but the T-89 has an (earlier design??) staggered gear selector, so maybe it went: T-89 (staggered gear selector) V (evolved into the) T-85 (aligned gear selector) V (evolved into the) T-16 (fully synchronized) V (evolved into the) T-10 (four speed) I found one listing of a T-85 cased three speed with a T-89 side cover; And with all these T-8x units it appears as though they could be assembled with or without an R10/R11 OD (the latter being a higher torque capacity unit); So there is for sure interchangeability between the T-85/T-89... but the T-16... ???? Any further thoughts or input would be appreciated...
Here...
So long, farewell. |
so what's the difference between the
T-16 M-13 |
M-13 is an RPO;
RPO = Regular Production Order An RPO doesn't indicate the end item, but instead a generic description; That generic description was defined by the vehicle and model year. From my research, M-13 was used by all divisions for many years to indicate "heavy duty "three speed synchromesh (manual) transmission"; There are the odd exceptions like 1969 where Chevrolet used MC1 to denote specifically which HD-3spd was to be used - in that instance it was the new Muncie three speed. T-16 should be the BW product code. regarding my prior post in this thread; From a little more research my suggested progression appears to be wholly in error...
